Negative boost PSI
Old Dec 31, 2014 | 11:53 PM
Pat Taugher's Avatar
Pat Taugher
Negative boost PSI
So i have a scangauge 2, and when at idle it shows .2 psi, when i go into high idle it is at 2.0 lbs...
Also when getting on the highway it shows a negative amount past 20 or 25... like at near or at WOT, it reads -14.5lbs..
Today i was passing a bigrig going up a steep grade like 4-7% not 100% sure... as i passed him i was at -17 psi, then the CAC tube blew off.... i was able to limp it to the top of the hill and re-tighten it and drive another 100 miles or so and get home... I think the hose blew off because i removed it about 400 miles ago to add my coolant filter and must have not tightened it 100% but seems to be fine now... ill keep yall posted on CAC issue, if it is an issue...
But i would like to know what my PSI is above 20 or 25... its a stock turbo, and stock engine... so i know its not off this world high...
Once i figure out what the numbers are... what PSI should i stay under for a stock engine.... no studs, and can i surpase that psi with a stock turbo?
Also happy new years forums!!!
Old Jan 1, 2015 | 12:34 AM
78fordman's Avatar
78fordman
28 psi is the magic number, and yes you can go past the 28 psi if there is a problem with the map sensor or turbo vains are stuck. With your Scan gauge they will do that with the stock boost gauge. There is a x gauge for boost, someone will chime in with the codes.
Old Jan 1, 2015 | 12:58 AM
Pat Taugher
how would i know if the vains are stuck? When it sits over night and its 50 or below it makes a little squeek or bird chirp sound then the jet engine sound from tail pipe, no cat or muffler. But there is not performance issues with the turbo other than blowing the CAC off which i think was my fault... im just wondering why the scangauge will go -10 - -15LBS usually after 25 lbs. idk if i were to add -10 to the 25, it would mean i am actually at 35 lbs, or it doesnt work like that? should i just ignore the bst? i never inputted a code for boost i went into settings and switched MAP to boost...
But again the truck runs fine, no boosting issues, again other than CAC. No codes, accelerates great.. i just dont want to be boosting like 45+PSI and blow my heads
Old Jan 1, 2015 | 08:52 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Do you have a tuner by chance? I noticed the same behavior on my Dashboss, but I assumed it had something to do with the tune I was running. I have since returned it back to stock, but haven't checked the boost since returning it to the stock tune.
Old Jan 1, 2015 | 10:36 AM
Pat Taugher
Nope no tunes
Old Jan 1, 2015 | 10:37 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Try this Pat,
https://www.ford-trucks.com/forums/1...scangauge.html
Old Jan 1, 2015 | 10:38 AM
2006lariat's Avatar
2006lariat
My truck does this too. I'm thinking a couple of the sensors are dirty. (ebp, map, baro....etc)
Old Jan 1, 2015 | 10:43 AM
78fordman's Avatar
78fordman
Put in the x gauge for boost. The one that comes on a Scan gauge will do this. use rusty link above.
Old Jan 1, 2015 | 10:46 AM
78fordman's Avatar
78fordman
Wrong thread
Old Jan 1, 2015 | 11:08 AM
dannyboy950's Avatar
dannyboy950
Would the truck even be able to run at a minus boost or is this just a pid interpritation?
Maybe I am just missreading.
Old Jan 1, 2015 | 11:11 AM
78fordman's Avatar
78fordman
It does not really have negative boost. It's just how the Scan gauge is displaying the information.
Old Jan 1, 2015 | 12:02 PM
250andEX's Avatar
250andEX
On the dashboss there is 3 separate selection I believe. One is map pressure and 2 are low and high boost. The low and high boost max at about 25# and show negative while the map pressure will show actual boost. I have a banks iq and they picked the boost pressure to show which does the same thing. They have a lot more money for r&d and I would have thought they would picked the pid that would show high boost but they didn't.
Old Jan 1, 2015 | 01:49 PM
Pat Taugher
ill input that as soon as i can futs with it! so which code from that link do i use if im at -14.5?
Old Jan 2, 2015 | 08:42 PM
Misky6.0's Avatar
Misky6.0
The negative boost value on the SG 2 is (probably) just a case of the math logic inside the SG2 being "simple". The SG2 infers from the MAP reading, so if you calibrate your MAP at 10k feet and then drop to a few thousand feet, the SG2 will report you have 5-10 PSI at idle. Clearly you do NOT have that but the SG2 thinks you do (because the MAP reading is so much higher at sea level vs. 10k feet).
Ambient air temp, humidity, and barometer all effect the MAP value.
Old Jan 2, 2015 | 10:18 PM
04badford's Avatar
04badford
Map
TXD-07e0221440 RXF-046285140680 RXD-3010 MTH-012203200000
Fear no Hill
6.7L Power Stroke Diesel
18
Mar 16, 2013 08:36 AM
brickie
Sep 11, 2010 12:11 PM
randy450r
May 18, 2009 04:03 PM
Jim Allen
Jan 4, 2007 10:28 AM
rickgmi
May 14, 2006 10:14 PM
