wastegate actuator, comparied ?
Old May 12, 2006 | 10:47 PM
rickgmi's Avatar
rickgmi
What Im wondering is about the Boost pressure
By turning in your factory actuator rod how much Boost have you hit ?
If you have a BigHead , How much boost have you hit ?
Please if possible was wondering these things on a stock Turbo ?
Old May 12, 2006 | 11:01 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
How much boost do you make now? Clamping the WG down will take your peak from around 17 to maybe 20-21 with a stock truck....it depends more on the truck than the turbo.
Old May 14, 2006 | 10:14 PM
rickgmi's Avatar
rickgmi
When my defueling starts I usally see 28 psi with the bighead, Im sure it really comes on after 25 psi, but it climbs fast when Im checking it and im using a digital gauge
