7.3 vibration under acceleration
Old Dec 30, 2014 | 05:04 PM
CW7.3's Avatar
CW7.3
After installing my dp tuner on my truck it seems to surge/vibrate and feel sluggish under hard acceleration at 1000-1500rpm, after 1500 it pulls like hell and the vibration is gone, it doesn't happen as bad when I drive in the stock tune or when I'm light on the pedal, any advice would be appreciated.
Old Dec 30, 2014 | 05:54 PM
fordman67's Avatar
fordman67
If t were me I would check fuel pressure while driving. After my chip fuel pressure became an issue.
Old Dec 31, 2014 | 07:01 PM
oldbird1965's Avatar
oldbird1965
Sounds to me the tuner has the throttle response down to low. One of my chips the throttle response is way to high. Just a matter of getting it retuned, unless Aaron is right about the fuel pressure.
Old Jan 1, 2015 | 09:06 AM
tjc transport's Avatar
tjc transport
i ain't rite
i would check rear driveshaft universals.. the fact it does it worse with the tuner on is because you are putting more torque to it.
Old Jan 1, 2015 | 01:30 PM
CW7.3's Avatar
CW7.3
The chip I bought was used and the guy said it was for a 5 speed so I figured it would work fine as my truck is also a 5 speed, after I bought the tuner I later figured out that his truck was an auto and he converted to a standard... Wouldn't the PCM be different in our trucks? Could that be why its sluggish at over 1/4 throttle in lower rpm's, like I said after 1500-1600 it seems to have good power, mabey the chip needs a reburn or the hpop is weak?
psmith0803
Jan 3, 2017 08:30 AM
Rayrosz
Nov 27, 2011 07:53 PM
PAVEMENTMAN
Aug 5, 2008 08:41 PM
bronk68
Jul 28, 2007 01:05 PM
bajhafords
Sep 24, 2006 09:47 PM
