What bushing kit do I need for shift lever?
Old Dec 29, 2014 | 07:51 AM
1972Herbie's Avatar
1972Herbie
I have a 1963 F100 and a few weeks ago I had an issue of me pulling the shift lever out, causing the shift rod to come out of alignment. I pulled the wheel yesterday and was able to get everything back in working order. However, the shift lever moves quite a bit, and I noticed it has no bushing. What kit do I need to order? Also, The previous owner lost the retaining pin, can I buy one new or what can I use to hold it in place? There has been a loose screw there since we got it.
Old Dec 29, 2014 | 10:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
3 speed M/T or A/T?
Old Dec 29, 2014 | 10:36 AM
1972Herbie's Avatar
1972Herbie
3 speed M/T or A/T?
I knew I was forgetting something! It's a 3 speed M/T on the column.
Old Dec 29, 2014 | 11:26 AM
NumberDummy
7210 shift lever fits into 7228 shift collar, is retained in place by (2) 7B125 trunnions and (1) 7208 coil spring.
Over time, the hole in the shift collar wallows out, the (2) trunnions begin to wiggle, eventually they fall out along with the spring.
Not shown w/a basic part number is a rubber sleeve that fits on the shift lever, the (2) trunnions and the spring fit thru this, then into the collar.
Is this what you're referring to when you say the shift lever moves quite a bit and the bushing (rubber sleeve) is missing?
All the parts are obsolete, but are available NOS
Old Dec 29, 2014 | 12:30 PM
1972Herbie's Avatar
1972Herbie
7210 shift lever fits into 7228 shift collar, is retained in place by (2) 7B125 trunnions and 7208 coil spring.
Not shown w/a basic part number is a rubber sleeve that fits on the shift lever, the (2) trunnions fit thru this, then into the collar.
Yes I believe I am in need of a rubber sleeve for the shift lever and a retaining pin. Any idea where I can get one? I am assuming ebay is my best bet. Also, is there any sort of rubber on the ball of the shift lever, where it goes through the shift rod?
Old Dec 29, 2014 | 01:08 PM
NumberDummy
Yes I believe I am in need of a rubber sleeve for the shift lever and a retaining pin (there isn't a pin, just 2 trunnions and a spring-see parts catalog pic).
Also, is there any sort of rubber on the ball of the shift lever?
No.
2) C0AA-7B125-A .. Trunnion / Obsolete
NOS PARTS LTD in Waxahachie TX has 8 = 972-937-2201.
MILLER OBSOLETE PARTS in Binghamton NY has 8 = 607-722-5371.
PARTS INTERNATIONAL in Farmers Branch TX has 10 = 888-727-0418.
WESLEY OBSOLETE PARTS in Liberty KY has 11 = 606-787-5293.
GREEN SALES CO. in Cincinnati OH has 27 = 800-543-4959.
1) 01A-7208 .. Spring / Obsolete
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
NOS PARTS LTD has 12.
WESLEY OBSOLETE PARTS has 24.
PARTS INTERNATIONAL has 50.
GREEN SALES CO. has 787.
1) 01A-7246-B .. Gear Shift Lever Rubber Sleeve / Obsolete
WESLEY OBSOLETE PARTS has 1.
MILLER OBSOLETE PARTS has 2.
NOS PARTS LTD has 5.
MCDONALD OBSOLETE PARTS CO. has 17.
Old Dec 30, 2014 | 08:27 AM
1972Herbie's Avatar
1972Herbie
Thanks for the help NumberDummy! Time to order some parts!
Shadowrider123
Apr 19, 2015 09:57 AM
Cdy1
1997 - 2003 F150
Jul 26, 2010 10:46 PM
tylerbrowntyler
Jul 29, 2008 03:16 AM
midnight_mp
Jan 20, 2008 05:30 AM
Ron Crawford
1978 - 1996 Big Bronco
Dec 16, 2003 11:30 AM
