Sponsored by: Real Truck
Clutch Position Switch Fault?
Old Dec 26, 2014 | 03:03 PM
KelsterB's Avatar
KelsterB
Hey Guys,
I'm getting a random 'no start' fault which I think is related to a clutch position switch. The dealer tells me the clutch pivot bushing and master cylinder push rod are worn out, which is causing the switch not to close when the clutch pedal is depressed.
Has anyone found a kit or fix for this issue?
93 F-350 7.3L Diesel 5 Spd 4x4, Std Cab, 8 Box.
Thanks,
KB
Old Dec 26, 2014 | 03:08 PM
Just Strokin's Avatar
Just Strokin
The bushing use to be made of nylon. They might be a different material now. They are replaceable. Depends on how ambitious you are.
KelsterB
British Columbia
Dec 26, 2014 02:19 PM
csangster
May 5, 2010 02:46 PM
4x4man514
Aug 28, 2004 01:12 AM
shendoa
Feb 5, 2004 05:52 PM
Kool Bronco
1978 - 1996 Big Bronco
Aug 18, 2003 05:05 PM
