1978 - 1996 Big Bronco
clutch interlock switch
Old Aug 18, 2003 | 01:50 PM
Kool Bronco's Avatar
Kool Bronco
Can someone please tell me how to replace the clutch interlock switch in my 94 Bronco? The truck would not start so I put a zip tie behind the clip as a temporary fix. As much as I hate to say it, I am girl and need detailed instructions.
Thanks
Old Aug 18, 2003 | 04:53 PM
ecarter50's Avatar
ecarter50
Clutch Pedal Position Switch
Removal and Installation
1.Disconnect the wiring harness from clutch pedal position switch.
2.Pull down on orientation clip to separate from switch tab.
3.Rotate clutch pedal position switch one-half turn to expose plastic retainer.
4.Push tabs together and slide retainer rearward and separate from clutch pedal position switch.
5.Remove clutch pedal position switch from clutch master cylinder push rod.
For installation, follow removal procedures in reverse order.
Old Aug 18, 2003 | 05:05 PM
DW2455's Avatar
DW2455
it dosn't matter that your a girl, boys and girls both were born equaly stupid on there birthday! DW
