British Columbia British Columbia
Join Chapter, Leader: F350towing
Clutch Position Switch Fault ?
Old Dec 25, 2014 | 12:32 PM
KelsterB's Avatar
KelsterB
Hey Guys,
I'm getting a random 'no start' fault which I think is related to a clutch position switch. The dealer tells me the clutch pivot bushing and master cylinder push rod are worn out, which is causing the switch not to close when the clutch pedal is depressed.
Has anyone found a fix for this issue?
Old Dec 26, 2014 | 02:19 PM
Zip's Avatar
Zip
Have you tried here? May find something.
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums
KelsterB
Dec 26, 2014 03:08 PM
t-bird1963
Jan 25, 2006 07:35 AM
shendoa
Feb 5, 2004 05:52 PM
Kool Bronco
1978 - 1996 Big Bronco
Aug 18, 2003 05:05 PM
