Boost gauge plumbing
Old Dec 21, 2014 | 10:16 AM
keithwld's Avatar
keithwld
I have an 87 f250 with a 6.9 that has an aftermarket ATS turbo and want to run a boost gauge. I am having trouble finding a place to hook the boost line on the intake. I am wondering if I can tap the adapter that is mounted on top of the intake where the air cleaner used to mount and now the pipe from the turbo is? Or does anyone know of another location that will work? Keith
Old Dec 21, 2014 | 10:27 AM
Chevy_Eater's Avatar
Chevy_Eater
Feel around the back of the intake hat.
Old Dec 21, 2014 | 10:48 AM
keithwld's Avatar
keithwld
What am I feeling for? Is there a fitting on the back and if there is it seems like it would be hard to get at it without removing the turbo plumbing.
Old Dec 21, 2014 | 01:50 PM
tecgod13's Avatar
tecgod13
Yes you can tap the intake "snail". I would remove it so you don't get any debris in the intake while drilling and tapping. While it seems like many of the ATS castings had a spot that was tapped and plugged, some of the castings, like the one that came with my kit, did not have a spot for a boost gauge.
Old Dec 21, 2014 | 11:55 PM
hairyboxnoogle's Avatar
hairyboxnoogle
My 088 kit has a port on the back of the snail. Its a PITA to find if you dunno where it is. Where the turbo outlet enters the snail, it should be a flat machined surface. Feel around there and you should find it. Mine had a 1/8"npt plug (1/4 square head) so once i got the dirt and oil out of the way it wasnt too bad to find. I suggest an electric sender type over the mechanical type.
Old Dec 22, 2014 | 07:37 AM
keithwld's Avatar
keithwld
I will have to look again as I did not find it the first time but was looking in the wrong place I guess. If it is not there I might check to see if the bolts that hold the throttle cable bracket in place go all the way through and if they do I might drill one and mount a nipple on it like the ones you can get from ATS for the intake. I already have the mechanical gauge so will use it if I can. Keith
Old Dec 22, 2014 | 04:20 PM
hairyboxnoogle
The bolts for the throttle cable are blind holes, they do not go through. I drilled a secondary port in my hat / snail. I wouldnt be concerned about drilling, but the tapping could easily leave crap in the intake you dont want in there. I had my cousin use an air hose and a towel on the turbo to pressurize the intake while tapping.
Old Dec 22, 2014 | 04:32 PM
Phy's Avatar
Phy
I'd still take it off to drill & tap it. If you really don't want to take it off, you can mitigate the risk of chips falling in by using grease. Drill slow, with heavy grease on the bit. If you drill slow enough to not generate much heat, the grease will stay thick and the chips will stick to it.
Grease on the tap will do the same thing.
mickpowell1967
Dec 19, 2010 02:37 PM
03F250FX4
Jun 16, 2009 09:09 AM
DOGSINIT
May 26, 2008 07:04 PM
94F250TD
Mar 10, 2008 11:03 PM
billaep
Mar 12, 2005 06:11 AM
