OBD2 Cable and Software
I'm new to the forum and am just about to finalize my purchase of a 2014 F150 XLT. I was curious about whether there's a reputable company that makes OBDII to USB cables and software that can be used to monitor the engine vitals via the ECU and do other things like readiness checks or to change electronic behavior of other features. I come from the VW-Audi world where Ross-Tech was the trusted company that made and sold these cables and software.
Thanks in advance for any guidance you can provide.
-Skid
It would be nice to log the RPMs, throttle position, cylinder timing retard, intake manifold pressure, air flow, actual timing, etc. in the same data set. This way I could quantify gains of things like a cold air intake or determine how aggressively a tune is modifying the timing and fuel mixture.
-Skid
Like I said, I'm not very good with it, but for simple stuff its pretty self explanatory (such as reading codes). Getting to higher level functions like mode $06 is somewhat straight forward, too. Check out google for the FORScan website, its a decent solution but definitely not the best out there.
-Skid
I used it primarily on my '01 7.3 powerstroke, but have also done diagnostics on gassers, as well. I have updated the software recently and is compatible with models up to, and including, 2014 for use with my 2013 F150 and Escape. It can display 9 live data parameters at once and does O2 sensor graphing. It also does KOEO, KOER, ABS, and other tests. You can even toggle certain switches/solenoids to test there functionality. I recently used it to test an EGR repair on my '05 Explorer commuter. -Skid
