Led light bar wire routing.
Old Dec 28, 2014 | 04:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
At 14V (design voltage) you are drawing more like 20A
That's still a big load.
30A fused is just to protect the truck while never being short on power.
If you're near the shore you might try a marine store. (chandlery)
They should have something that is panel mount and can handle that current.
The SAE plug pictured above is fine for a solar panel, but definitely is not 14Ga. wire.
Yes, there are many umbilical cables on rockets and missiles.
Preflight data acquisition and arming are almost always hardwired.
Old Dec 28, 2014 | 05:18 PM
Diesel_Brad's Avatar
Diesel_Brad
Wow! 30amps is A LOT. Make sure you have a plug rated for that along with the correct wire for the length it will be run
Old Dec 28, 2014 | 05:23 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
300W of LED's is a huge amount of light if they are any good.
I want to see nightime pic's when you are done.
Old Dec 28, 2014 | 06:08 PM
Crewcabber's Avatar
Crewcabber
52" bar 100 3watt Leds. 40 amp relay with 30 amp fuse. If my math is correct 300 watts divided by 12v gets me 25 amps. I have looked at some twist lock acc. Socket . Rated for 30 amps. I need a shallow fitting what ever I use it will be mounted into the side of the cab lights.
Old Dec 28, 2014 | 06:10 PM
Crewcabber's Avatar
Crewcabber
I just found these I can screw it to the side and a dab of silicone to Seal it. Then the light bar is removable and I'll have a power port out side as well.
Old Dec 28, 2014 | 06:12 PM
daddylee100's Avatar
daddylee100
Definitely want to see some pics.
Old Dec 28, 2014 | 06:13 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
!2V truck is not 12V.
Alternator should have the system at 14.35V with the engine running.
A six cell automotive battery should be 12.6 volts at rest.
i.e. the next morning, after surface charge has come off.
Old Dec 28, 2014 | 06:18 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Seriously?
I don't think there's any way that is going to pass 21.4A continuous.
Old Dec 28, 2014 | 06:28 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Data sheet and sales brochure.
20A max.
http://www.waytekwire.com/datasheet/...SalesSheet.pdf
Old Dec 28, 2014 | 06:48 PM
Crewcabber's Avatar
Crewcabber
Your right the bar is rated from 12 to 30 volts. And missed the info on the data sheets thank you sir.
Old Dec 28, 2014 | 06:54 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't want to see that connector heat up and short out like those darn 2G alternator plugs do.
The graphs show they are derated and the temps climb as more current is passed through them.
Try and find something rated at 30A, just like the fuse.
Old Dec 28, 2014 | 06:57 PM
Diesel_Brad
30 amp plug
Metri-Pack Sealed 280 | Metri-Pack Automotive Electrical Connectors | Automotive Electric Connection
I Use these style plugs all the time but the ones I use are only 20 amp rated but work flawlessly
Old Dec 28, 2014 | 10:19 PM
  #28
Crewcabber's Avatar
Crewcabber
That's what the other one is I posted but I can screw it to the cab light or come up with a small list bracket under the cab light screw to gold it in place. I found some regular accs. Plugs light in our trucks (theaux)power plug but haven't found any shallow enough. 30 amp and weather proof just to long
exbxtoy
Sep 24, 2016 07:04 PM
tsw902
Mar 22, 2016 08:52 PM
mbxmitch
Feb 2, 2012 10:34 PM
Foxracer7248
2004 - 2008 F150
Nov 11, 2007 06:38 PM
royale5
Aug 3, 2006 09:09 PM
