So i got a pacer f5 light bar today and went and hookd up the light bar to my 4 prong connector and then i tied in the reverse wire which works awsome. But i tied the turnsignal wire in with the light bar and the only time the light bar flashes amber for the turnsignal is for the left hand turn signal the right side dosnt work. Is there two differnt wires the the left and right turnsignals and how would i go about tieing both of them in with the one red wire that comes off the light bar? Thanks you!
Hi and Welcome to FTE, sorry to hear about your problems with your new Pacer light bar.
Fwiw: Yellow should be Left and the Right should be a green wire off of the truck.
......But I can't seem to find a online installation manual...(that's stated to come with the package ) I assume they didn't send you one in the box. The packaging is claiming to have a five wire hook-up; incl. back-up lights.
I'm assuming you see the standard Flat 4-pole with a single flying lead for the back-up light coming off of the light bar?
