Dumb Question
Old Dec 15, 2014 | 10:56 PM
65F-250FATTYLEEN's Avatar
65F-250FATTYLEEN
Dumb Question
Hey I don't know if I am doing this right but I have a quick question. I drive a 65 F-250 as a daily driver (for now) and I am having some clearence issues with my fan on a new radiator I installed. Can I drive the truck with out a fan when its cold out. Atleast untill i can afford an electric fan to fix my clearence problem. Just wanna make sure im not going to do damage to anything. I am only driving less than 10 miles a day and never at a stop for very long. I am well aware that this is a stupid question but I figured I'd ask anyhow. I know enough to get me into trouble when it comes down to it. Thanks for the Help!
Fatty
Old Dec 15, 2014 | 11:51 PM
resonateur's Avatar
resonateur
I wouldn't, especially at lower speeds which don't provide adequate volume of air flow through the radiator. Opinion.
Old Dec 16, 2014 | 12:14 AM
tbm3fan's Avatar
tbm3fan
Clearance issues. How long is your fan spacer? I don't think Ford has longer than a 3 1/2" spacer that I have seen. Mine was 3" before installing a shroud and there was still about 2" left in front of it.
Old Dec 16, 2014 | 03:23 AM
willowbilly3's Avatar
willowbilly3
Open highway you could probably get away with it. I put an electric fan on a 72 with 302 and it hardly ever came on with a 190 fan-stat
Old Dec 16, 2014 | 04:32 AM
TBird Larry's Avatar
TBird Larry
Fatty
When it gets really, really cold I block the front of the radiator with a piece of cardboard so the engine will warm up and the heater will work. I wish I could take the fan off in the winter sometimes but the cardboard works great. Using an electric fan would be a good thing to have in place of the old engine fan. Most new cars come with electric fans now days anyway.
If you notice in the winter you see a lot of semi's with their radiators zipped up part way to help them warm. Some have shutters that close also.
Just depends on how cold it is when you drive around. That's what the TEMP gauge is for, keep your eye on it.
If you have icicles hanging on your grill you need to worry if your antifreeze mixture is good enough.
Good luck.....
Old Dec 16, 2014 | 04:45 AM
jowilker's Avatar
jowilker
65F-250FATTYLEEN Welcome to and the Slicks Forum
These old trucks have a huge frontal opening, unless you are sitting and idling for extended periods you really don't need a fan at all this time of year. 100 degree summer heat is a different day.
New vehicles are designed much differently and have different requirements with fans. As long as the truck is moving forward about 20mph there is more air flow there than any fan can deliver.
John
Old Dec 16, 2014 | 09:24 AM
65F-250FATTYLEEN
My radiator was bad when I bought the truck about 3 years ago. It finally blew up. I bought a aluminum core but messed up on my measurements when I sent it out to get brackets welded on. (Im an idiot with a learning curve?) Now the fan is WAY to close. About 1/4 of an inch. Motor mounts are new but I worry about damaging the fan. I just want to take the fan off for now till I can buy a electric fan.
Old Dec 16, 2014 | 11:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As tbm3fan said in post 3 .. there's a spacer between the water pump pulley and the fan. If your truck still has it, remove it.
1965 F100/250 240/300 I-6: There are 4 different spacers, shortest is 1.07" long, longest is 1.93" long.
1965/66 F100/250 & F350 (with SRW) 352 spacer is 3.10" long.
In 1981, I had a local radiator shop make up a custom 4 row radiator for my 1965 F100 352.
The original spacer was too long, so I used one from a 1979 Econoline 302 that was 2 1/8" long.
Old Dec 16, 2014 | 11:28 AM
65F-250FATTYLEEN
aww heck im stupid
Like I said im an idiot! Im smelling what you are stepping in! There is a very large spacer in the truck about 2 inches. Ill see if I can get a smaller one! Thanks for the tip!
Old Dec 16, 2014 | 12:01 PM
DoubleOh7's Avatar
DoubleOh7
... but I worry about damaging the fan.
I had to chuckle at this. Sorry. The fan is probably $30 to replace whereas the radiator is closer to $300. I'd be more worried about damaging the radiator.
But now that I have that out of my system...
...you'll need to be sure when shortening the fan spacer that you verify rearward clearances too. You may hit the front of the alternator or power steering or crank pulley if you shorten it too much. Figure your rearward clearance first and add about 1/2" to that and subtract that from the current spacer length. That's your safe range.
The fan is ideally about 3/4" away from the radiator with no shroud, but can be further away with one.
And yes, going with an electric fan is a good idea, though maybe overkill (cost to benefit ratio) but it is thermostatically controlled and may, in cold-brrr weather, never come on. And depending on summer temps may be undersized. You need to choose a CFM rating great enough to match the need.
Old Dec 16, 2014 | 12:13 PM
NumberDummy
C5TZ-8546-B .. Fan Spacer - 1.07" long / Obsolete
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
TXTrailerdaddy
19
Mar 2, 2019 08:45 AM
Spyderjohn
Mar 14, 2012 01:27 PM
302flareside1992
35
Jul 29, 2010 06:58 PM
johnsf
Aug 11, 2006 08:28 PM
drewcoolness99
Sep 3, 2004 09:38 PM
