Quick Electric fan Question
Old Sep 2, 2004 | 05:14 PM
drewcoolness99's Avatar
drewcoolness99
For those of you who switched over to electric fans did you put the old fan shroud back on? or did you just put the fan on and thats it?
Old Sep 3, 2004 | 12:22 PM
Blurry94's Avatar
Blurry94
I've seen some e-fan setups without the shroud and they work fine.
Old Sep 3, 2004 | 12:35 PM
MustangGT221's Avatar
MustangGT221
Shouds are not always necessary but do help in cooling. It helps to suck the air through the radiator instead of from next to the radiator.
I assume your electric fan bolts right up to the radiator and therefore it is not necessary (didn't think of that last night when u IMed me, sry).
The fan on the stock setup is a few inches away from the radiator..so they use a shroud to help it suck the air through the radiator instead of air from the surrounding area. It also doubles as protection from getting hit by the blade.
Old Sep 3, 2004 | 04:18 PM
95 F150's Avatar
95 F150
I'm running dual electric fans without a shroud, with my setup it was not neccesary.
https://www.ford-trucks.com/user_gal...=50133&width=0
Old Sep 3, 2004 | 09:38 PM
broncobasher's Avatar
broncobasher
I really don't think that if the fan you have is mounted tight to the radiator that the shroud will do any good. If you can mount it away from the surface, then it will help.
Most electric fans have a built in shroud. If you bought one that is just a fan and no housing, then you should use your factory shroud.
BroncoBasher
Scubaman154
1997 - 2003 F150
Sep 24, 2012 08:48 AM
Hongster
Jan 30, 2012 06:47 PM
MikeFlorida
Apr 23, 2007 12:14 AM
97rangerguy
Nov 15, 2006 04:10 PM
Terran
22
Jun 10, 2006 07:10 PM
