Fan question
Old Aug 11, 2006 | 07:47 PM
johnsf's Avatar
johnsf
Fan question
I'm replacing my fan and shourd assembly and I'm not sure which way the fan should face.I'm replacing the old flex type fan with a steel one and it looks nothing like the one I'm taking out.the new one has the tips of the blades bent some and I don't know if the bends are supposed to be toward the radiator or away.Theres a warning label one one side of the hub but it doesn't say if in or out. The new fan's a Flex-a-lite if that helps, any ideas
John
Old Aug 11, 2006 | 08:28 PM
monsterbaby's Avatar
monsterbaby
Lets see if I can explain this that makes sense. you should see a star shaped piece that the blades are attached to. Then the blade is bend away from that at an angle, well that angle should point to the engine.
if that doesn't make sense let me know.
