Fuel Tank
Old Apr 20, 2016 | 12:03 AM
FordTruckGuy96's Avatar
FordTruckGuy96
Fuel Tank
I am rebuilding my entire truck this year and was wondering what size fuel cell I can fit under the bed. I have a dual tank bed but only one tank. I would like to go as big as possible because I drive from one side of the state to the other and would like to make it in one go, without stopping. I know I have a 16 gallon side tank currently, can I go bigger than the 19 gallon tank? I'm not worried about the weight, truck rides better weighed down anyway. Also has anyone been able to find diesel filler necks?
Old Apr 20, 2016 | 06:57 AM
Motorhead351's Avatar
Motorhead351
Only easy option, that's a bolt in, is to get a bronco tank and stick it in the rear tank location. They are 32~34 gallon capacity but you'll have to put your spare tire in the bed, get the correct module/pump assembly and correct tank straps, other than that it's pretty much a plug and play deal.
Someone may offer an increased capacity , side tank, but I'm not aware of whom.
If your diesel, then I'm not sure if this applies, as I honestly don't know the specifics on diesel fuel delivery requirements.
Old Apr 20, 2016 | 02:19 PM
FordTruckGuy96
So find one from a bronco then. Sounds like a good plan. And yes I am diesel but would be using this tank as more of a feeder tank, run a hose from one to the other and let the fuel drain into the side mount tank.
Old Apr 20, 2016 | 04:33 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
Spectra fuel tanks F26 e or d is a 38 gallon rear tank. several people have done it, I have. there are several write ups as well.
FastTaurusSHO
6.2L V8
92
Mar 23, 2025 11:08 PM
FordTruckGuy96
Jul 15, 2016 07:53 PM
Bigdawg5565
Sep 25, 2015 04:05 PM
DEREK D.
May 24, 2006 04:09 PM
jnsredrose
Jan 14, 2002 12:31 PM
