351 or 460?
Old Dec 14, 2014 | 12:47 PM
JackErnie's Avatar
JackErnie
351 or 460?
My daughter gave me an 1981 2WD F250 Custom long box for Christmas. It has a 3 speed auto tranny. She got it from the executor of a neighbor's estate.
According to the VIN, the engine is a 351. According to the executor it's a 460. I checked all the usual places where there should be a tag on the engine, but can't find any.
Can anyone suggest how to tell which engine this is?
Thanks in advance for any assistance offered.
Old Dec 14, 2014 | 01:19 PM
Trackerrrr's Avatar
Trackerrrr
http://www.wrljet.com/fordv8/glance.html
Try this.
Old Dec 14, 2014 | 04:41 PM
Gary Lewis's Avatar
Gary Lewis
As an '81 F250 the engine should actually be a 400, not a 351M. However, you really can't tell the difference between the two from the outside as only the pistons and crank are different. There should be a label on the radiator filler and/or valve cover telling which engine family it is. And if you post the Certification label from the door jam we can decode it.
Bubba's site has lots of info on the 335 Series, which includes the M and the 400. the 351M/400 has 8 valve cover bolts and the 460 has 7, IIRC. And the M/400's thermostat housing bolts to the block while the 460's bolts to the intake.
Old Dec 14, 2014 | 04:54 PM
ctubutis's Avatar
ctubutis
The M/400/Clevelands are the only engines to have a fuel pump with vertically-oriented mounting bolts.
Old Dec 15, 2014 | 07:06 AM
tree medics's Avatar
tree medics
My 1981 F250,4X4,Super Cab, Long box, has the 351M. When I bought it, I was told it had a 400. The label by the radiator, reads, Engine family 6.6/5.8 Engine displacement 5.8. When I had the motor rebuilt, it was confirmed to be a 351 M. I have an R V cam in it and the original 2 bbl. carburetor, wow did that wake this motor up.( Rebuilt in 2001. still runs very strong)
Old Dec 15, 2014 | 07:36 AM
Gary Lewis's Avatar
Gary Lewis
Interesting. There goes another of my beliefs. (Soon I won't know what to believe.)
Yes, a cam swap, and a good timing set, can really make the diff on an M. Rusty is similar although his M has a Eddy manifold and 4bbl, and he gets the job done. I recently pulled a car-hauler trailer quite a ways, and light I got 10.5 MPG, which is better than Dad's truck did with a stock M and no trailer. And, during the return with a 50 Chevy pickup on the trailer the right rear spun as I pulled out from a stop with lots of throttle. No sand, no bumps, just torque.
Old Dec 15, 2014 | 07:47 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
No 460's in that year.
They came back in '83.
You can tell a 351 M from a W by the fuel pump.
Or whether it has a timing case (W), or just a funky 'shelf' (M) at the front of the block.
Old Dec 15, 2014 | 08:19 AM
Franklin2's Avatar
Franklin2
A 460 would bolt in fairly easy though, so he needs to check to make sure.
Old Dec 15, 2014 | 08:47 AM
Gary Lewis's Avatar
Gary Lewis
Do 460's require changing out the perches? I know the perches are stamped 351M/400, so must be specific to those engines.
Old Dec 15, 2014 | 11:18 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
460 perches are stamped '460'
I dont know how or if they differ from 335 perches.
Old Dec 15, 2014 | 06:16 PM
Gary Lewis's Avatar
Gary Lewis
Oh, yes, they certainly do as the 335 series perches are stamped "351M/400".
Old Dec 15, 2014 | 06:21 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
During my 2008 engine swap I took detailed photos of the 2 slot perches after I power washed the engine bay and frame.
Towards the beginning of my Flickr set "460 Repower"
Vinford
Jul 17, 2018 07:39 AM
tikkakoski
Sep 26, 2010 01:41 PM
eleanor67
Aug 31, 2003 10:41 PM
kylefort
Feb 14, 2002 10:16 AM
AaronW
Jan 2, 2002 04:58 PM
