Sponsored by: Real Truck
Steering Stabilizer Replacement?
Old Dec 7, 2014 | 06:49 AM
blueh2o's Avatar
blueh2o
Will replacement of the original OEM steering stabilizer with a higher quality stabilizer tighten up my steering wheel play, making is more responsive?
Old Dec 7, 2014 | 07:47 AM
Iaff113's Avatar
Iaff113
Will probably a little
Parts Jimmy's Avatar
Parts Jimmy
No, correcting the problem with your steering will though. IE loose tie rid ends, draglink, sloppy steering gear.
Old Dec 7, 2014 | 11:15 AM
blueh2o's Avatar
blueh2o
Is there a process for checking these? Like put front of truck on stands so I can have someone turn wheel, while seeing what moves vs. what does not?
Old Dec 7, 2014 | 10:14 PM
droldsmorland's Avatar
droldsmorland
Yes. Youtube it.
Year, make, model and mileage please.
Its something that a seasoned wrench could show you. Not easily described on line but Ill try. Crawl under it. Have someone in the cab turning the wheel back n forth with short heavy strokes with engine on so power steering is working. There should not be any slop in the linkages.
The ball joints need to be checked a different way. Jack up truck enough to get a 6' 2x4 under the tire. Lift up and down on 2x4 simulating chassis deflection while someone looks at the ball joints for abnormal movement....
There I tried. Keep in mind there are some safety concerns you need to watch out for while jacking any vehicle...wheel chalks, jack stands etc...If in doubt or above your abilities take it somewhere good like a commercial type truck chassis shop and have it inspected(not a chain store). There is other items you need to look at too. Steering box, leaf spring perches and pins(if equipped) etc...
Old Dec 7, 2014 | 10:57 PM
EXv10's Avatar
EXv10
Nope, not at all...............band-aid.
llmflyfisher
May 8, 2025 08:45 PM
351Cleveland C4
15
Jul 15, 2013 01:06 PM
Goatjacket
13
Aug 15, 2012 06:33 AM
nater350
Jan 28, 2007 02:19 PM
