20 deg delta
Old Dec 3, 2014 | 09:55 PM
kbf1961's Avatar
kbf1961
20 deg delta
Ive had an 11 deg delta for quite sometime and suddenly it seems I have a 20 deg delta. ECT 182 EOT 202. 2006 model truck. Should I do oil cooler? EGR cooler replacement or delete? Standpipes and dummy plugs while Im in there?
Old Dec 3, 2014 | 10:01 PM
WatsonR's Avatar
WatsonR
I'd replace the thermostat first and see where it comes out at. Was that after 20 minutes of level, no hill, 65mph driving?
Old Dec 3, 2014 | 10:45 PM
KDAVID1's Avatar
KDAVID1
Agreed. Tstat change first. If still above 15° then it's time for a proper flush then new cooler.
2006 F350 4X4
Old Dec 4, 2014 | 09:25 AM
kbf1961's Avatar
kbf1961
It was, minus a couple of small overpasses. I will replace tstat today and take another look at it. Thanks
Old Dec 4, 2014 | 09:36 AM
WatsonR's Avatar
WatsonR
change the o-ring as well, should be able to get a t-stat for $30. MSRP is $28.83 for Motorcraft RT-1169
Old Dec 4, 2014 | 09:43 AM
TxMav's Avatar
TxMav
Could one of the sensors (ECT or EOT) be bad?
Old Dec 4, 2014 | 10:15 AM
WatsonR's Avatar
WatsonR
If in doubt, swap them as they are the same sensor. But just looking at the numbers, Id say no, they read about where they should for EOT, ECT is low... indicates the t-stat may be old and worn out, weak spring and time to go.
Old Dec 6, 2014 | 11:44 AM
kbf1961's Avatar
kbf1961
Installed the new t'stat yesterday and looks like EOT 204,205. ECT 188, 190. So back to the original question. Oil cooler time. Whats the thought on EGR? Replace ? Delete? 2006 model truck. OEM parts?
Old Dec 6, 2014 | 04:18 PM
LivingLarge's Avatar
LivingLarge
You are just about there, if you have the funds I would do it. If your not ready, just keep your eyes on it. I was at 20+ over when I replaced my oil cooler... I did all OEM... Don't know if your studded but since there half way there it may be a good time for that. I did not do the EGR delete and opted for new oem. Just my .02
Old Dec 6, 2014 | 06:59 PM
az4x4bronc's Avatar
az4x4bronc
I don't know if you do need a new cooler but your EOT is low. The EOT may not matter but I would get a second opinion.
Old Dec 7, 2014 | 12:08 AM
BryanStein's Avatar
BryanStein
Confirm gauges are good first.
I just did an oil cooler with egr delete because I was pushing a 20 delta. My eot got to 256 while towing a 32 ft camper this summer. I run a 6 delta now.
Old Dec 7, 2014 | 03:38 AM
Yahiko's Avatar
Yahiko
Yes on the OEM. Are you going to heavy tow with it? I had at one
point thought I was going to go with the external cooler and after some
research and reading more about the unit and all. The price is what pushed
it over to the not going to do side. If you do the flush and get things clean
your risks seem to drop way down. I know that over a weekend we can get
your truck done and install the new cooler. On top of that also install the new
set of stand pipes and dummy plugs. The one odd thing I would like to have
on hand is the 4 head copper washers and the 2 coper washers on the fuel
filter housing. As for the delete I don't trust my TIG ability at this point. I do
have a good cooler that could be welded up if you let me have your old on in
exchange for it. (good as in a non-leaker). The one thing to know before going in
would be if the STC fitting had been done of not. If not then it would be good to
do that while the top is out of the way. I have all the odd ball tools other than the
nipple cup O-ring tool. You only need that if you have a leak. I want to buy one
and may have one soon.
What coolant are you thinking about using?
Trying to think if I missed anything.
Oh and if we have to work on this while
it's cold I do have one of the big Assed
torpedo heaters. Runs on diesel,Kerosene red or clear
and jet fuel.
Sean
gpeade
Apr 18, 2019 07:30 PM
fyredude
Mar 13, 2015 08:45 AM
Diegoaverta
Feb 21, 2015 10:17 PM
craziejoker
Nov 13, 2012 02:46 PM
bpounds
Aug 24, 2007 12:43 PM
