1988 f150 bed mounts
Old 12-02-2014, 08:02 PM
rugermack's Avatar
rugermack
rugermack is offline
I am doing my lift over x-mas and want to do the bed mounts, I already bought an Energy Suspension master kit. Of course the kit comes with nothing for the bed.
What is everyone else using here?
Old 12-03-2014, 08:56 PM
Toplait's Avatar
Toplait
Toplait is offline
I have my bed bolted directly to the frame. There is no bushings. Just flat paper thin pieces of plastic that go between the bed and the frame.
O----I know the pain that you will go through when replacing the cab mount bushings. I used a home-aid puller out of steel pipe I made and ended up stripping a bolt out. I ended up cutting the entire cab mount bushing and bolt.
I took the bolt to Fastenal and they had nothing what I needed. I ended up getting a piece of All-Thread, nuts, and washers. Worked out good.
I don't know what you can use for your bed to raise it up. Maybe some one else can chime in.
Good luck to you.
Old 12-03-2014, 09:40 PM
rugermack's Avatar
rugermack
Thank you, I have never removed a bed before(never had any reason to). I'm not raising it either just wanted to remove it to do sending units/fuel pumps, fuel lines, paint frame, brake lines, and do lift kit. I thought while I was at I would do those also.
Old 12-06-2014, 08:24 PM
michaelleiterman's Avatar
michaelleiterman
michaelleiterman is offline
Getting the bed off isn't too big of a deal at all. You'll need to take the six bed bolts out; 2 near the front, 2 in the middle, and 2 near the back. Then go under the bed and disconnect the filler neck from the fuel door to the tank (or both if ya have dual tanks). After that I'm pretty sure there's a wiring harness for the taillights you just need to disconnect and you're all good. Someone may add anything I forgot but yeah. Myself and two buddies removed my old bed off of my truck one morning after football in the summer, its not too heavy.
Good luck, I assume its a body lift as your putting em under the bed?
Old 12-07-2014, 08:06 AM
rugermack's Avatar
rugermack
No body lift, doing a 4" lift I just got in the mail over my xmas break. While I have things apart, I thought I would do those too. Apparently there isn't much between the bed and frame. I am actually taking the bed off to paint frame, do fuel lines, fuel pumps and sending units. Since truck is 26 years old I am replacing a lot of the old stuff, weather it's bad or not. I hunt a lot and don't like to break down in the middle of nowhere. When truck is done I will sell my 2 diesels and move on. I don't tow anymore so they are both going.
Old 12-07-2014, 08:07 AM
rugermack's Avatar
rugermack
Really just trying to figure out what goes between bed and frame before I take truck apart.
Old 12-07-2014, 10:31 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Nothing goes between bed and frame other than some thin plastic sheets(sometimes) other than that it bolts straight to the frame. After the energy suspension bushing are installed, you may need some washers as shims for the bed to get everything to sit level. The ES bushings are not quite perfect
Old 12-07-2014, 10:53 AM
rugermack's Avatar
rugermack
Thanks Brad, How thick are the plastic sheets? Nobody lists selling them(that I could find)
Old 12-08-2014, 05:03 PM
Diesel_Brad
Maybe a 1/16" thick. No need for them if they are gone, just bolt the bed straight to the frame. Bit if it REALLY bothers You, just some old inter tube
Old 12-08-2014, 05:19 PM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
2X on the inner tube used in-place of those weak plastic parts. They are there to keep the bed from squeaking while the truck is flexing.
When I did my bed swap, those plastic washers were wore out so I left them out. I got tired of the squeaking bed and used the inner tube as a replacement. No more squeek!
Old 12-08-2014, 06:19 PM
rugermack's Avatar
rugermack
I hate squeaks
Old 12-08-2014, 07:38 PM
Diesel_Brad
Never had a bed squeak, ever. And I have had hmmmm 70 or so trucks. Not one of them had anything between the bed and frame other than a steel body shim or two.
Tighten the bolts and they will be no problem
old_blue1
03-17-2015 08:53 AM
fyreduck1921
08-06-2013 07:08 PM
77_150
01-07-2011 02:31 PM
Coneynew
Paint & Bodywork
06-08-2006 05:35 PM
Hit Man X
13
06-06-2003 10:34 PM
Quick Reply: 1988 f150 bed mounts
