4x4 Problems
Old Dec 2, 2014 | 11:04 AM
2003DSG30's Avatar
2003DSG30
4x4 Problems
Whats up guys. I got a 95 f150 4x4 and the 4x4 is giving a bit of a problem. I just recently did a manual hub conversion and the 4x4 dont work. Im not sure it even worked when i bought the truck. Anyway, when i engage 4x4 the front shaft spins but the wheels DO NOT. Could i have done something wrong on assembly? it was pretty straight forward install. This is my first 4x4 truck so im not sure what to check. Thanks for any help
Old Dec 2, 2014 | 11:19 AM
Conanski's Avatar
Conanski
If you jack a wheel off the ground and lock the hub does the corresponding drive axle turn when the wheel is spun? If not then you did something wrong with the hub install, if it does then you may have a blown front diff.
Old Dec 2, 2014 | 11:24 AM
2003DSG30's Avatar
2003DSG30
nope neither wheel turns. But what i did was put the truck on a lift and put it in 4wd with all 4 off the ground. of coarse only the back wheels spun. not sure what i could have done wrong. There was only like 2 washers and 2 nuts in the kit. installed according to mile marker directions
Old Dec 2, 2014 | 11:35 AM
dixie460's Avatar
dixie460
So the front driveshaft spins in 4x4, that's good. Means your transfer case is working.
Now when the front driveshaft spins, do the front axle shafts turn as well?
If so, then your hubs are not locking.
If not, then your front diff is messed up.
Old Dec 2, 2014 | 11:39 AM
2003DSG30's Avatar
2003DSG30
Axle shafts do not turn, just the front shaft
WhiteHorse04
Nov 14, 2011 11:59 AM
pittmick
Feb 3, 2011 01:41 PM
04xcur
May 11, 2009 09:47 AM
78ford351m
Jan 10, 2009 08:51 PM
BigB4000
Offroad & 4x4
May 1, 2003 11:51 PM
