292 help
Old Dec 2, 2014 | 04:05 PM
svolpone's Avatar
svolpone
did you clean the tank before you replaced all that stuff?
Old Dec 2, 2014 | 04:40 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Originally Posted by raytasch
The accelerator pump is supposed to give a quick shot of extra gas just as the throttle is opened. It is adjustable. When you bring the throttle off idle, you should see two squirts of gas and then no more.
Ray is correct here. When looking down the throat and giving it a manual throttle increase you should just see a shot of gas added to the venturi and not a continuous stream that doesn't stop.
Often as the engine is accelerated it takes more voltage to deliver a spark to the plugs and a condenser that is partly shorted (resistors and transistors typically open on failure, condensers/capacitors typically short internally) can cause a pretty good stumble or nearly die as the spark from the points isn't fully delivered to the downstream components but is sent to ground through the shorted condenser.
If you eliminate fuel delivery as being a culprit keep the innocent looking condenser in mind. It's been the cause in at least 6 cases I know of this year.
Old Dec 2, 2014 | 06:06 PM
My1964ford's Avatar
My1964ford
I have replaced the condensor along with new plugs, wires, coil, cap and rotor, and the battery within the past couple of months.. I may get another condensor to make sure I didn't get a bad one to begin with. But it has been running great untill the past week so you'd think that it would have never ran right (or not run at all) if the condensor was a issue
Old Dec 2, 2014 | 06:10 PM
My1964ford's Avatar
My1964ford
Its actually a brand new tank
Old Dec 2, 2014 | 06:32 PM
skidoorulz's Avatar
skidoorulz
As I said with motor not running look down the throat of the carb and open the throttle. Open it all the way. You should get a shot of gas almost the entire stroke of the throttle. If you get a shot just off where idle would be and then nothing that is not right. Since this happened all of a sudden and has not been an issue for a long period of time. I am still saying bad diaphram on accelerator pump. Not a kinked fuel line because that would cause problems at higher speeds and hard acceleration because the flow may not be able to keep the bowl full. Check the diaphragm. You can buy just the diaphragm at a good parts store
Old Dec 2, 2014 | 06:58 PM
Shadowrider123's Avatar
Shadowrider123
My 292 seems like it is down on power, but since this is my first one and it is a low compression engine with that funky crossover exhaust, Im not sure how it should perform.
I do not that not having a fuel filter at all cant be helping.
Old Dec 2, 2014 | 07:10 PM
My1964ford's Avatar
My1964ford
I tried what you said and it has continual flow untill about slightly less than half throttle then just stops and no more fuel comes out after that, even at full throttle
Old Dec 2, 2014 | 08:36 PM
Jim Beckers's Avatar
Jim Beckers
Replace the condenser. New ones have a high failure rate. I had a new one fail after less than 100 miles and it will cause the truck to run goofy (like a fuel related issue) before complete failure.
corkel
Dec 8, 2014 05:20 PM
Reed_50
Oct 14, 2009 08:45 PM
gilllawn
Dec 26, 2006 01:32 PM
nick65f100
Jun 13, 2005 10:05 PM
hflu
Oct 29, 2003 09:27 PM
