4wd auto locking function. Twilight zone?
Old Nov 27, 2014 | 06:51 PM
Snuggyworm's Avatar
Snuggyworm
Thanks y'all for the prompt responses. I can engage 4wd high just fine but only from a dead stop. Weird. I know. I'm onto the idea of something upstream. Down stream seems fine.
I haven't changed the vacuum pump yet. I changed the pulse hub solenoid. I changed the main vacuum line. I changed the connector line between the main vacuum line and the pump, tank and solenoid.
Pump seems to run fine. It takes about 1 min or so to fill the vacuum reservoir tank from empty. KOEO. Would it be the pump being weak? Possible.
So when I switch to 4wd on the fly, is the vacuum pump sending the vacuum to the hubs? If so, then I may have a weak pump then.
Could it be the axle vent hose? I've read somewhere tat if the vent hose is clogged, it may throw tat defrost condition as well.
Thanks guys. This is baffling me.
Sent from my iPhone using IB AutoGroup
Old Nov 27, 2014 | 06:53 PM
Snuggyworm's Avatar
Snuggyworm
Originally Posted by BLADE35
Dom how you been Seams like my 03 hub has 3or 4 seals per hub But I know your 05 setup is different Kinda an odd issue you have going on Could be A wire issue or leaking vac when moving due to vibrations
I've been ok Benny. Hope ur doing good.
Could the blend door actuator also play a part in this 4wd fiasco? But then again, my ac and heating works like it should.
Thanks.
Old Nov 27, 2014 | 07:00 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Ron mentions the reservoir should vacuum in about 30 seconds. 1 minute is weak pump.
Josh
Old Nov 27, 2014 | 09:16 PM
mhoefer's Avatar
mhoefer
Defrost is the default on the HVAC control when no vacuum to hold at other settings. I am with Watson, I think your pump is on the way out or a leak at the tank ect. I have a new pump amd lines, amd re did the hub lube. Be very careful to have those o rings properly lubed and use a fresh seal on the outside end. My 05 clearly engages better when moving, always has. Slower speeds sometime doesn't work as well. Colder temps also cause issues, it's to do with how hard it is for the vacuum to turn the locking in the hub when the lube turns to goo.
Old Nov 27, 2014 | 10:50 PM
Snuggyworm's Avatar
Snuggyworm
Originally Posted by Bullitt390
Ron mentions the reservoir should vacuum in about 30 seconds. 1 minute is weak pump. Video Link: http://youtu.be/85brOL9KTDU?list=UU6s_EctGCrqClSIThpSicJw Josh
Thanks josh. That's helpful.
Old Nov 27, 2014 | 10:53 PM
Snuggyworm's Avatar
Snuggyworm
Thanks mike. I'll replace the pump and see what's up. Btw, what's ur iPod mod? I'm curious now. Is it the whole aux adapter thing or something different?
Old Nov 28, 2014 | 02:39 AM
Yahiko's Avatar
Yahiko
Dom,
Here are some things to ponder.
In the diagnosis section you will
find the vacuum hold times for the hubs
Sean
Old Nov 28, 2014 | 09:34 AM
Snuggyworm's Avatar
Snuggyworm
Originally Posted by Yahiko
Dom, Here are some things to ponder. In the diagnosis section you will find the vacuum hold times for the hubs Sean
Thanks Sean!
Old Nov 28, 2014 | 09:48 AM
diverseth's Avatar
diverseth
I had the same problem. After much frustration I finally got it fixed by replacing the vacuum solenoid for the locking hubs located on passenger side inside fender.
Old Nov 28, 2014 | 09:59 AM
mhoefer's Avatar
mhoefer
Yes, I have an FRDX aux input which is a direct input I use for sat radio and iPod, phone for tunes. It's direct digital so it sounds wayyyyyyy better.
Good point above on the solenoid, mine was fine, but the pump didn't suck hard enough. Also, there is a small set of lines that can crack, and loose vacuum to the solenoid as well, it's short and cheaper than the long one to both wheel hubs. If you time the pump till it shuts off with each line plugged, you can trouble shoot the leak by looking at the time it takes to come to full vacuum.
Old Nov 28, 2014 | 12:07 PM
Snuggyworm's Avatar
Snuggyworm
Yes, I have an FRDX aux input which is a direct input I use for sat radio and iPod, phone for tunes. It's direct digital so it sounds wayyyyyyy better. Good point above on the solenoid, mine was fine, but the pump didn't suck hard enough. Also, there is a small set of lines that can crack, and loose vacuum to the solenoid as well, it's short and cheaper than the long one to both wheel hubs. If you time the pump till it shuts off with each line plugged, you can trouble shoot the leak by looking at the time it takes to come to full vacuum.
Even that short line has been replaced.
I wanted a direct iPod adapter to the stereo but the 05s are the red headed stepchild of ford. They make adapter interface for 03 to 07, except the 05. Damn.
Old Nov 28, 2014 | 03:37 PM
Yahiko's Avatar
Yahiko
Dom,
That adaptor might work still.
You other option is get an 06 stereo and swap them. The stereo head unit
needs to have the AUX button. What you get with the PIE adaptor is a right
and left input line to plug into.
This should do the trick for the 05
Ford auxiliary input converter interface adapters aux cable jack mp3
Sean
EDIT : Dom have a look at this one I think it will do what you want.
Ford PIE FRD04-AUX Auxiliary input Adapter radios with AUX
Old Nov 28, 2014 | 09:23 PM
  #28
mhoefer's Avatar
mhoefer
My truck is an 2005 too. They make one if you have the right stereo, does your stereo have an aux button on the left side? If it does, I got the adaptor you need. I got my original one from Crutchfield, I did replace about two years ago, it stopped working properly, but it was about 6 years past warranty by then, so I got another. What yahoo says but you don't have to have a non 2005, it just needs the aux button. Mine is a six disc stacker, am, fm, and has the aux button. If you don't, you would need to upgrade to the higher end model, but, it wouldn't be worth it, a double din JVC, Kenwood or what have you would get you the digital/digital input.
Old Nov 28, 2014 | 10:59 PM
  #29
Yahiko's Avatar
Yahiko
Just avoid Pioneer. There tech support SUCKS more than just a little bit.
Sean
Old Nov 29, 2014 | 04:47 AM
  #30
Tdraym's Avatar
Tdraym
I have a 2012 F250 auto/lock hubs, When in auto it doesn't seem to engage 4w drive. I put it in N at a dead stop, dash tells me it engaged , Front wheels don't get me out of snowbank when rear wheels are spinning ? Do I need to get up to a 3-5 mph speed for auto hubs to kick in or engage ? Most of the time I am just trying to push snow, not fast. Now the reason I ask is because If I Lock the hubs in lock and turn **** on dash to 4w high, or low, Everything on dash tells me same thing, but I know it engaged from the power of push force. Any comments please, The next is can I leave the Hubs locked in lock 24/7 w/o harming anything other then bad mpg, The truck only has 24k mi. So I need some help Please.
