just died
Old Nov 23, 2014 | 09:44 PM
nothin but fords's Avatar
nothin but fords
just died
Was driving down the hiway, my truck just died, its an 06 f350, 6.0, ran a diagnostic test on it with my SCT tuner, it gave me a p2291 code, injector control pressure low, engine cranking. Been told all kinds of things can be wrong, fuel filter, fuel pump, oil pump? Not alot of money to spend, don't know where to start, any ideas?
Old Nov 23, 2014 | 09:49 PM
BLADE35's Avatar
BLADE35
The best thing you can do right now is get a gauge
I know it sucks to spend money on something that won't fix the problem but it'll give you a direction to go and more than likely pay for itself in the end
Sounds like a high-pressure oil leak this would also fit the diagnostic trouble code you got
Old Nov 23, 2014 | 09:51 PM
BLADE35's Avatar
BLADE35
Welcome to FTE these guys would get you taken care of
Old Nov 23, 2014 | 09:57 PM
nothin but fords
What kind of gauge?
Old Nov 23, 2014 | 10:01 PM
nothin but fords
It does have an oil leak, not sure where its coming from, up front on the passanger side
Old Nov 23, 2014 | 10:06 PM
CPB1's Avatar
CPB1
You need a San Gauge II or something that will plug into the OBD2 port and read live data.
The truck ever had the STC upgrade? How about upgraded stand pipes and dummy plugs?
Old Nov 23, 2014 | 10:09 PM
CPB1's Avatar
CPB1
The oil leak is in the high pressure oil system inside the engine, you won't see it. You can do an air test and confirm there is a leak, and possibly were it's coming from.
Old Nov 23, 2014 | 10:12 PM
nothin but fords
Ok, thanks for everyone input, I will get that gauge and go from there,
Old Nov 23, 2014 | 10:16 PM
04badford's Avatar
04badford
Does the ICP sensor have oil out the Connection side by chance? X2 on some Gauges there a must to Monitor things
Old Nov 23, 2014 | 10:24 PM
CPB1's Avatar
CPB1
I run the San Gauge II but there are other options. I leave it in the truck and don't even have to touch it. It turns on/off automatically.
Old Nov 23, 2014 | 11:25 PM
BLADE35's Avatar
BLADE35
His description of where is oil leak is coming from is right about where that ICP sensor is located
Find your ICP sensor in the passenger side valve cover and unplug it and then try to start your truck from the description it sounds like that's
But if that's the problem Once you unplug it should let the truck start
superhooperduty
Aug 20, 2012 12:27 PM
ford7.3l
13
Jul 27, 2012 04:16 PM
simsbud
Apr 20, 2012 11:25 PM
kudunk06
Oct 26, 2011 09:26 AM
jimtx
Jun 3, 2009 01:08 PM
