long crank when cold
Old Nov 24, 2014 | 11:36 AM
the4by4freek's Avatar
the4by4freek
Originally Posted by KBOFVA
which program are you using to get you spec screen
Torqe pro for android and an elm327 bluetooth adapter
Old Nov 24, 2014 | 01:54 PM
mustang_309's Avatar
mustang_309
Hey just for fun, next time you go out to do a cold start, pull the secondary filter and see if there is fuel in the filter housing.
Old Nov 24, 2014 | 02:41 PM
KBOFVA's Avatar
KBOFVA
Thanks I am looking for one for my tablet
Old Nov 24, 2014 | 06:05 PM
the4by4freek
Just for fun? Lol...what would that mean if there wasnt any in it? I run motorcraft filters every 10k. Also have done blue spring upgrade. I have no idea why its doing this...the truck runs perfectly once started...starts fine hot....starts up in 14 degrees without a bunch of fanfare....pretty stumped really. It didnt do this before the new FICM....could programming cause this? Or should I say, lack of programming
the4by4freek
It will be the best $20 you ever spend!
Old Nov 24, 2014 | 07:33 PM
mustang_309
If you go out in the morning to start it and find no fuel in the fuel filter housing it would point to a failing fuel pump, even if there is fuel in the bowl I would turn the key on and see if the fuel instantly rises or gets air bubbles in it, I would have someone else turning the key on so you can have them shut it down quickly if needed. If you had a fuel pressure gauge installed you would already know if this were the problem because it would take a long time to build fuel pressure. What my thinking is here is that the fuel pump loses prime while sitting over night.
Old Nov 24, 2014 | 07:38 PM
the4by4freek
I'll check it in the morning and post an update
Old Dec 13, 2014 | 11:30 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
Thanks for sharing the existence of this thread, Bismic!
Software on the FICM will not cause an elongated crank, no.
I'd be curious to see your fuel pressure during the elongated cranking times, but would of course be most interested in seeing what your injection control pressure and IPR duty cycle numbers are during this time as well.
When you say longer cranks, what are we talking about? 15 seconds? 5 seconds?
Regardless, if you had a local buddy with a 6.0, you could always pop the FICM we sent you into it to determine whether the same issue existed or could, for that matter, send it back on in for us to look at. A Powerstroke FICM will start and run any other Powerstroke.
Hope this helps!
Old Dec 14, 2014 | 06:26 AM
the4by4freek
Hope this helps!
Update...fuel in bowl after sitting overnight.
Icp during crank goes up faster than torque pro can keep up with so thats a mystery.
One puff of black smoke at startup then just a light haze on cold start..definitely fuel haze...no oil
Ipr duty cycle is 38% from the best i can tell...like i said...it changes faster than torque can keep up with.
When i say long crank...15 seconds or more
The craziest part as of yesterday....three days in a row now....cranks right up within 3 seconds! Been in the low 20s. No rattle on startup, no black smoke, nice smooth idle within a couple of seconds. Its the most baffling issue i have ever seen. I,was ready to pull valve covers and do stand pipes and dummy plugs...but im holding off now. Everything i have read and researched points to that....but at the same time, it does start hot and cold (although long crank when cold )
Old Dec 14, 2014 | 06:45 AM
bismic's Avatar
bismic
Have you posted any readings during a 20 second crank when it had not started yet? From what I can tell (and there are some things that seem contradictory), the readings that you have posted (the torque pro screen shots) are all after starting.
From your post above, are you saying that it still has an issue w/ a cold start or for the last 3 days you have had no issues?
When the IPR was 38%, what was the ICP doing? When you say the IPR was changing so fast, was it bouncing around (up and down)?
Old Dec 14, 2014 | 06:46 AM
87crewdually's Avatar
87crewdually
On those long cranks is it showing the cam/ crank sensors are synced? It might not be synced initially until it's cranked then suddenly creates a signal.
Old Dec 14, 2014 | 06:56 AM
the4by4freek
Originally Posted by bismic
Have you posted any readings during a 20 second crank when it had not started yet? From what I can tell (and there are some things that seem contradictory), the readings that you have posted are all after starting.
I havent had any problems the past three days.
The readings change quickly because it has bluetooth lag and the readings change faster than bt can relay. Same happens with IPR. Not bouncing around but quick climb.
The screen shots are immediately after startup and then after full warmup. I can try another screen shot during cranking...but with the way its been starting the past three days, i may not even have time to push the button!
Old Dec 14, 2014 | 07:02 AM
  #28
FICMrepair.com
Former Vendor
The IPR Duty Cycle at 38% and ICP going up so fast that TorquePro can't keep up with it - is that when you are experiencing the long crank or what you witnessed when it started right up as it has been doing for the last three days? I'm guessing these numbers are from the last three days, but just guessing (which is why I'm asking )
Old Dec 14, 2014 | 07:06 AM
  #29
the4by4freek
That is what i have experienced when it was long cranking...the past three days, i havent monitored....been a crazy week and i havent powered up the app before startup
Old Dec 14, 2014 | 07:30 AM
  #30
FICMrepair.com
Former Vendor
Interesting. Did you happen to check if you had crank sync, cam sync, and/or FICM sync during these long cranks?
