Also I was gonna ask for the ipr is it possible to remove it without removing anything
Sorry, should have seen this before. Yes the IPR can be easily removed. It requires a deep well socket. There are quite a few write ups on how and on how to rebuild. Give me a few minutes and I'll see what links I have saved on "how to"
several threads about welding pieces to sockets etc. really don't need to make a special tool unless you'll be working on these engines alot. Just use the deepest 1 1/8 you can find. May have to only insert the ratchet or extension partially into socket to allow room
