7.3 Help Please
Old Nov 22, 2014 | 08:16 PM
robcruz1105's Avatar
robcruz1105
Exclamation 7.3 Help Please
Hello im new to this forum but i need some advice I have a 2002 f250 7.3 4x4 it all started about three weeks ago i started up my truck in 90 degree weather and it cranked for awhile but didnt think anything of it. When i was driving with no load it lost all power then it had rough idle like if it was cammed with a lope idle. I turned around and went back home once i got home it completed died just turned off by itself so i tried turning it on and it would crank and crank alot until it starts. I left it untouched for about two days then tried to start it up again and it cranked a couple of times then fired right up but then started to idle weird the rpm guage was high low high low for a couple of seconds i floor the pedal and it runs fine then it dies. My friend put his computer on it and it displays an exhaust sensor. I then youtube and figured it must be the fuel filters or the sending unit fuel filter, so i replaced all which were very clogged but then tried starting it again and the problem is the same now it doesnt even start up just cranks. We placed the computer on it again and now reads IDM. I want to know could this be the problem I dont want to spend $300 and for that not to be the solution!!!i made a youtube video of the first days Please help sorry its long
Old Nov 22, 2014 | 08:27 PM
robcruz1105
here is the youtube link from the first couple days before it got worst
Old Nov 22, 2014 | 09:28 PM
The Brad's Avatar
The Brad
Do a search for UVCH or under valve cover harness. Then do a search for 50 cent mod. The uvch is how the injectors get the signal from the IDM. Its pretty common for the plug under the valve cover to work its way off. When mine worked loose, I had an intermittent miss. I check the code and it was showing #2 injector high to low side open. Then it got worse, so I pulled the codes again and it then showed #2 and 4. I was in the middle of nowhere at the time, so I pulled the valve cover and pushed it back in to get me home and did the 50 cent mod a week later.
I also noticed in your video that you're low on fuel. Its possible the pick up foot broke off in the tank, but you said you cleaned that, so prpbably not. Hope this helps.
Old Nov 22, 2014 | 09:31 PM
robcruz1105
let me search that and thanks alot for your help and no the pick up was fine in the tank
Old Nov 22, 2014 | 09:48 PM
The Brad's Avatar
The Brad
Here you go...
https://www.ford-trucks.com/forums/1...-material.html
Old Nov 22, 2014 | 09:56 PM
robcruz1105
Originally Posted by The Brad
thanks for the help i really appreciate it
Old Nov 22, 2014 | 09:58 PM
robcruz1105
that video rally helped that's exactly what my truck is doing man ill check the connections tomorrow morning
Old Nov 22, 2014 | 10:16 PM
The Brad's Avatar
The Brad
Here's a you tube vid of the 50 cent mod.
Old Nov 22, 2014 | 10:29 PM
robcruz1105
nice man wish i knew all these tricks
Old Nov 22, 2014 | 10:42 PM
The Brad's Avatar
The Brad
Everything I know, I learned from reading these forums. There is a huge wealth of info here and some pretty smart contributors.
When you get the problem fixed, make sure you post the fix here to help others with the same symptoms.
Welcome to the forum.
Old Nov 23, 2014 | 12:03 AM
robcruz1105
thanks man i sure will ill try that quarter trick tomorrow morning and post the results hopefully it works i love my beast it runs strong and pulls hard
Old Nov 30, 2014 | 09:17 AM
robcruz1105
update on my truck well i put my buddies IDM and still same thing, i opened up the valve covers and checked the injector harness connections and they were tightly connected so im in a dead stop i dont know what it could be now!!!!!!
Old Nov 30, 2014 | 11:18 AM
cps's Avatar
cps
What codes did you retrieve when you hooked it up to your buddies scanner?
Old Nov 30, 2014 | 11:25 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Glow plugs would be my first place to look with the way it sounded when starting in the video. You said you changed the fuel filter, how about the filter screens in the tank? Have you checked them? But you said it runs fine when warmed up though.
How many miles are on the truck?
Old Nov 30, 2014 | 11:27 AM
CampSpringsJohn
Just read back through the thread and I see you did check the tank.
What about the Cam sensor? Have you changed that? If so, what sensor are you using? Ford and International brands are the only ones we've found to be reliable.
