Engine died while driving
Old Nov 22, 2014 | 11:24 AM
raptor2005's Avatar
raptor2005
Hey want to see if I am on the right track. 2005 6.0 f250 no programmer, I did an egr delete, oil cooler upgrade and 5 in turbo back exhaust no cat. I also change the IPR valve a little over a year ago.
On my way to work truck running fine lost power and killed. Towed truck home and it starter up fine. FICM is showing 48 volts no check engine light but I can't pull codes.
I am thinking high pressure oil problem pump or the oil rail plugs any way to check or am I on the wrong road
Thank in advance for all your help
Old Nov 22, 2014 | 11:31 AM
jswartz84's Avatar
jswartz84
Sounds like your on the right track.
First, digital gauges will help diagnose a high pressure problem. If proven, do an air test to find out where.
Second, make sure it's getting fuel.
bismic's Avatar
bismic
What brand of oil cooler did you install?
Old Nov 22, 2014 | 11:33 AM
raptor2005's Avatar
raptor2005
I did filters and oil change about 800 miles ago fuel pump comes on can't remember what name the cooler was o
Old Nov 22, 2014 | 11:35 AM
bismic's Avatar
bismic
If it was a Dorman oil cooler, it wasn't an upgrade and it has a failure prone gasket (and weak internals).
Old Nov 22, 2014 | 11:37 AM
raptor2005's Avatar
raptor2005
What is a good scan tool and where can I find a tool to test the high pressure oil system I will double check the oil cooler
Old Nov 22, 2014 | 12:27 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Click on the link below for a general idea of what's available.
https://www.ford-trucks.com/forums/1...eral-info.html
sonofdixie
Apr 19, 2018 08:24 AM
MaxOut
Mar 3, 2017 08:08 AM
Gmangh15
Oct 26, 2011 04:43 PM
scootroo
Jul 4, 2011 02:01 AM
highsmit99
Mar 24, 2011 06:05 AM
