upper engine oil leak 97 7.3
Old 11-17-2014, 05:39 PM
Asytole61's Avatar
Asytole61
Asytole61 is offline
Need your help guys. Changed my oil the day, probably put in about just short of 15. gallons of rottella with a quart of Lucas synthetic additve.Dipp stick read just above fill level. Drove the truck for 2 hrs notice oil leak underneath originating from passenger side of valley. Some oil in rear of valley but hoop and lines are dry. Seams to becoming from spider on passenger side. Thanks
Old 11-17-2014, 05:55 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
The only oil in the spyder is from the ccv. Have you checked the turbo pedestal or ebpv area?
Old 11-17-2014, 06:03 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
15 gallons!!!!! No wonder it's leaking. Lol.
Old 11-17-2014, 06:21 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
X2^^^^^
And just a word of caution. It is not a good idea to use additives in the oil for our trucks. Lucas is good stuff, but not for our trucks. The injectors run off high pressure oil. The pressure can be up to 3000 psi. Additives like Lucas and others will cause the oil to foam at those pressures and could over time damage the injectors and also make the truck not run at it's full potential. Straight oil with no additives is the best way to go with our trucks.
Old 11-17-2014, 07:01 PM
Asytole61's Avatar
Asytole61
oil Leak
Nick, thank you for pointing out the possible obvious.lol .Darren what I meant to say for the pedestal not the spyder. The oil seams to be leaching from the passenger side of the pedestal.
Did I make a mistake by adding to much oil with the additve? Would draining a quart or so possibly help or did I do some damage?
Yeah, this my first truck.I appreciate the help guys.You too Nick.
Old 11-17-2014, 07:50 PM
427 fordman
You didn't hurt anything if its overfilled a little. Sounds to me like you have a turbo/pedestal oring leaking. There are 2 sets of orings there. One on top of the pedestal and one set between it and the block. I think its just a coincidence that it happened right after your oil change.
Old 11-17-2014, 07:57 PM
Asytole61's Avatar
Asytole61
Thanks Darin I'll check on it this coming weekend. Clean out with rags.Try to fine the exact origin. I'll try and take some photos to post.
Old 11-21-2014, 08:02 PM
Asytole61's Avatar
Asytole61
post photos
Excuse my in expertise but how do I post a photo to this thread?
Old 11-22-2014, 05:17 AM
427 fordman
I use photobucket and copy the img link and paste it here.
crazytwo
25
03-20-2015 03:55 PM
arkredneck
17
11-16-2014 07:58 AM
Mdt1992
07-13-2010 11:26 AM
bfog99
43
06-02-2009 06:50 PM
bomberopm
1999 to 2016 Super Duty
09-05-2006 02:23 AM
Quick Reply: upper engine oil leak 97 7.3
