Weird MAP sensor issue
Old Nov 15, 2014 | 08:41 AM
CanadianTRK's Avatar
CanadianTRK
Hey guys, I've got a 99 F450 with a bit of an odd issue. The truck starts very well, cold or warm, but has no throttle response and low power. For a time the truck would move if I unplugged the MAP sensor (was just poking around and found it), now i have nothing. A buddy has AE, so we can try to diagnose it, i would like to stay out of a shop if possible. It will rev in neutral and park so I believe the TPS is still good. What should we test with AE? Thanks!
Old Nov 15, 2014 | 08:59 AM
HD Rider's Avatar
HD Rider
Almost sounds like a fuel issue.
If you open the bowl drain and turn the key to run, do you have a strong flow of fuel shooting out?
Old Nov 15, 2014 | 09:01 AM
CanadianTRK
Fuel pump is brand new, dropped the tank and cleaned the screens (they were REALLY dirty), checked fuel pressure while the truck would still move 60 PSI under load. Fuel filter is brand new as well.
Old Nov 15, 2014 | 06:50 PM
Tugly's Avatar
Tugly
Look at your ICP and IPR. When warm, the ICP should be about 500, and the IPR (ICP DC) should be in the neighborhood of 9-10%, but stable. If the ICP reads 500 and the IPR is way low, the ICP likely has oil in the connector and is lying to the PCM. Pulling the ICP connector and driving the truck in stock tune is a quick and safe experiment.
Old Nov 16, 2014 | 04:12 PM
CanadianTRK
Sounds good! I'll give that a try tomorrow. Thanks for the quick replies by the way!
0811Artillery
Dec 18, 2017 02:23 PM
X-70STANG-F150
Jul 18, 2017 10:10 AM
highmilesguy
Dec 19, 2015 08:59 PM
jeff630
6.7L Power Stroke Diesel
Sep 25, 2015 11:08 AM
jhl3
50
Dec 7, 2014 09:27 PM
