6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Flush?
Old Nov 7, 2014 | 06:25 AM
yiannis50's Avatar
yiannis50
Flush?
how to flash a 6.4 oil cooler , my oil temp is increasing 250 F
thanks
Old Nov 13, 2014 | 10:50 PM
Tennesseepowerstroke's Avatar
thanks
You need to post this in the appropriate diesel forum for a good answer. This is the Ranger forum. I am sure a moderator will move it for you if you don't post in another forum.
Old Nov 14, 2014 | 07:12 PM
SANDDEMON08's Avatar
SANDDEMON08
thanks
Unfortunately it can not be flushed, once pluged they require replacement. The coolant passages are so small once clogged even a flush agent will not pass thru to clean it. Are you getting 250 oil temps cruising or towing can you explain the symptoms. How many miles are on the truck, what kind of Maintance has been done. If the coolant has not been serviced properly, it degrades and can lead to a clogged oil cooler.
Normal driving you should not see more then 8-10 degrees diffrence between coolant and oil temp.
Old Nov 15, 2014 | 06:31 PM
parkland's Avatar
parkland
Is there really nothing to clean these out with?
Boiler cleaner?
After all the EGR coolers and oil coolers around, there isn't a single chemical formula that can be used to dissolve the crap out of it?
Old Nov 15, 2014 | 07:00 PM
yiannis50's Avatar
yiannis50
2008 6.4 87.000 miles, 1600 rpm crusing goes to 220F at 2.000 240F Towing 17.000 LB trailer pushing 60 mph 265F reduce power mode water at 197F down to 1500RPM 5 min 240F oil. IDLING ALMOST EVEN TEMP??????
Old Nov 15, 2014 | 07:35 PM
SANDDEMON08
Boiler cleaner?
Once you remove it I'm sure it could be cleaned in a ultrasonic tank, but with the labor and cost to get it out i don't think its worth messing with best to just replace it.
Here is link to a view of the oil cooler cut open, as you can see the passages are very small. The photo is for a 6.0 but the 6.4 is very similar
6.0L Power Stroke Oil Coolers - DTS Articles - Articles - Articles - DTS
Old Nov 15, 2014 | 07:45 PM
SANDDEMON08
Sounds like your on the right path, a bad oil cooler could cause this issue. Running empty you shouldn't see more then a 10 degree delta difference. I would get it looked at ASAP, also i would have the oil changed if you haven't already and still driving it after hitting 265. I wouldn't recommend towing trailers for the time being until the issue is resolved. If you continue to run over 240 you can expect to have engine damage at some point.
Old Nov 15, 2014 | 08:30 PM
parkland's Avatar
parkland
I'm going to switch my truck over to evans coolant in the spring.
Waterlogged
Mar 3, 2016 01:23 PM
tassmannn
Aug 10, 2015 04:26 PM
yiannis50
Nov 1, 2014 08:04 PM
p8ntballer442
Aug 19, 2011 11:11 PM
Blaster7Romeo
Jun 6, 2008 09:44 PM
