Sponsored by: Real Truck
Engine Oil Cooler Issues...again
Old Aug 10, 2015 | 02:54 PM
tassmannn's Avatar
tassmannn
Recently I changed my 2006 6.0 oil cooler at 144k due to a large variance between coolant temp, and engine oil temp. Prior to doing that, I did a coolant flush, and added coolant filter. Well Only 6k miles later, I started having the same issue and replaced the thermostat and also did a reverse coolant flush to try and clean out the oil cooler, and another full coolant flush as well as replace the coolant filter again. I am now once again getting those high oil temp numbers over the coolant temp. Yesterday pulling my tractor I had 200ish engine coolant, and 238 engine oil temp. Is there somewhere else I should be looking. I was told the an external oil cooler would be a solution. Any help would be appreciated.
Old Aug 10, 2015 | 02:56 PM
evan1242's Avatar
evan1242
you said i am not getting high oil temps. did you mean i am now getting high oil temps?
check the delta after a cold soak to rule out any sensor bias.
Old Aug 10, 2015 | 03:08 PM
tassmannn's Avatar
tassmannn
Yeah Evan, thanks...I edited post. Cold soak?
Old Aug 10, 2015 | 03:17 PM
evan1242's Avatar
evan1242
let the truck sit for about 12 hours. the EOT and ECT at that point should not be more than 1 or 2 degrees different, if any.
Old Aug 10, 2015 | 03:27 PM
tassmannn's Avatar
tassmannn
Yeah, that's the case. When I let it sit at idle, oil temp will will get within 5-8 degrees of coolant temp
Old Aug 10, 2015 | 03:35 PM
MisterCMK's Avatar
MisterCMK
Does the EOT and ECT match up before you start it after the cold soak?
Old Aug 10, 2015 | 03:38 PM
tassmannn's Avatar
tassmannn
pretty close
Old Aug 10, 2015 | 03:39 PM
tassmannn's Avatar
tassmannn
What about BulletProof External oil cooler? They have one that eliminates the factory filter as well, and I heard the plastic parts in those can break too.
Old Aug 10, 2015 | 03:49 PM
evan1242's Avatar
evan1242
how much is pretty close?
just think an 8 degree bias can make a 15 degree a delta a cool 7 degrees.
Old Aug 10, 2015 | 03:53 PM
MisterCMK's Avatar
MisterCMK
He is looking at a 38 degree difference.
Looks like it is time for an oil cooler again.
Old Aug 10, 2015 | 03:56 PM
tassmannn's Avatar
tassmannn
It is usually about the same when I start up. Will need to verify when I go home as I drove one of my Broncos today. When not towing, the difference is usually gets to about 10 degrees between the two. When towing heavy, and not even pushing it 45-55 mph, it can be greater than 40 degree difference, and eventually will throw the wrench at me and the code. Comes down pretty quick at idle though
Old Aug 10, 2015 | 03:58 PM
evan1242's Avatar
evan1242
oh ok, either i missed that or you added it in. lol
either way, he is right, looks like its time for a new oil cooler.
Old Aug 10, 2015 | 03:59 PM
tassmannn's Avatar
tassmannn
What about my external oil cooler question?
Old Aug 10, 2015 | 04:05 PM
tassmannn's Avatar
tassmannn
Is there anything else that can cause this that I can search for?
Old Aug 10, 2015 | 04:10 PM
MisterCMK's Avatar
MisterCMK
Is your cooling fan working normally?
Radiator isn't blocked?
It sounds like the BPD system might be a good idea in your case. I've never been a big fan of that system as the factory one typically works just fine provided the cooling system is clean. Plugging up an oil cooler in 6k miles is definitely not a good thing.
Are you doing the work yourself?
If it were my truck, I would probably flush the cooling system again and then put another OEM oil cooler in it. That BPD set up is quite spendy.
