Is it too late?
Old Aug 19, 2011 | 03:15 PM
p8ntballer442's Avatar
p8ntballer442
Is it too late?
Newbie Diesel driver here...
I am really enjoying learning about the Diesel world. However my bank account is not. The advice on this forum is awesome. Anyway I just had An EGR delete and new oil cooler done. I would have went with new studs too but I didn't have the money. The reason I did this was my EGR died and killed everything else along with it. I had Oil in the coolant as well. The mechanic that I used seemed to do the repair well but I don't think he flushed the coolant properly (according to the procedure in the tech folder). He only used dawn to clean the oil out. My question is if I do a complete flush with VC-9 right now am I just going to clog up my new oil cooler? Is it too late to do a proper cleaning? Thoughts? Suggestions?
I apologize... I am sure this is addressed in another thread but I couldn't seem to find it.
Old Aug 19, 2011 | 03:18 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Dawn is a very good way to clean oil out of a cooling system. Used it many times with good results. I wouldn't worry about it and just leave it how it is.
Old Aug 19, 2011 | 03:21 PM
p8ntballer442
Ok...that makes me feel a little better. What are the conditions/situation where a cleaning with VC-9 would be used then?
Old Aug 19, 2011 | 03:35 PM
da-bees's Avatar
da-bees
Wherther it is or is not "to late" does not come in to question for your case. Reason beeing you could not do a vc-9 flush until the egr cooler was been replaced anyhow.
Assuming you are talking about a 6.0 since that is what this forum is about. You should install aftermarket guages and a coolant filter yesterday,well today is almost as good. The oil and coolant tempatures observed will tell you wherether it is nessary to vc-9 flush and if so,the after temps will let you know if the oil cooler clogged as a result therby requiring another teardown for another oil cooler.
Cheer up,you didn't nessarly make a mistake.
Old Aug 19, 2011 | 04:12 PM
p8ntballer442
The Oil temp and the coolant temp should not be more than 15 degrees apart correct?
Old Aug 19, 2011 | 05:02 PM
rdunagan's Avatar
rdunagan
correct! get a coolant filter though!
Old Aug 19, 2011 | 05:13 PM
Ian123's Avatar
Ian123
IMO, if it ain't broke don't fix it. Now I've learned that saying doesn't always apply when it comes to this engine, but in your case I think it does. If your ECT/EOT delta is fine, which I would assume it is considering your EGR and oil coolers are brand new, just leave it alone. That is why I haven't done a coolant flush yet. I've heard too many stories on here about people ending up worse than they started after attempting a flush.
Old Aug 19, 2011 | 05:22 PM
p8ntballer442
Thanks for the great responses. I have heard of those stories too and I was concerned I would be one of the "unlucky ones". My truck would be a big paper weight if I killed the new oil cooler I just don't have the $$$ for that any time soon. I've been eyeing the sinister coolant filter and as soon as I can get the cash it will be on order. I've also started coming up with a plan for guages. Just to clarify though I did not replace the EGR I deleted it.
Old Aug 19, 2011 | 05:44 PM
BLADE35's Avatar
BLADE35
for gauges a scangauge is cheap and covers alot well worth the 160.00$$
It will monitor ECT and EOT FICM ICP IPR volts boost and a bunch more those are just some of the main ones
www.scangauge.com
if your oil cooler does plug again its new enough that it can be flushed clean
IMHO its just the oil coolers with high miles on them that cant be flushed that stuff is too packed in there
Old Aug 19, 2011 | 06:24 PM
p8ntballer442
what the .... I just looked in the degas and its full of tan brown sludge. The Mech said he flushed with dawn several times. Do yo guys think I have another leak or is this residual stuff that he missed?
Old Aug 19, 2011 | 06:44 PM
BLADE35's Avatar
BLADE35
It could be left over IDK hows your oil leval
If it popped the oil cooler before did the mechanic change all the rubber hoses there also supposed to change the heater core, radiator,coolant bottle,water pump but since its summer and hasnt been on it probably didnt get any in there the heater core
watch that oil leval close but I bet its just left over stuff It take alot of flushes to get it cleared up some of the techs recomend using simple green cleanwer to flush after a popped oil cooler
sorrey man a poppped oil cooler is a mess from hell
Old Aug 19, 2011 | 11:11 PM
rdunagan's Avatar
rdunagan
yea its left over i would imagine. it happend to me and what i did was flush the crap out of it. then still had some so i got a coolant filter which in the first 1k it got it all out. then i got a new bottle and cap and now its crystal clear!
green_95
Jul 5, 2019 02:07 PM
Paul Hicks
Mar 27, 2014 04:30 AM
Canadianpowerstroke
Oct 14, 2012 06:49 PM
FICMrepair.com
Jun 16, 2011 06:53 PM
polosabre
Nov 14, 2010 10:43 PM
