does the replacement EEC need to be flashed?
Old Nov 16, 2014 | 04:12 PM
Trimman1224's Avatar
Trimman1224
still missing
I did install the EEC mentioned in post #12. Truck has more power, a lot more, but still misses. Your suggestion to test the injectors using noid lights will be done tomorrow. I just got off the phone with a local mechanic fire fighter friend and he is going over it in his shop tomorrow. He likewise thinks it may be an injector. Fuel rail pressure at last test several weeks ago was 45lbs. as I recall. He is also going to do another compression test.
Thanks to all that responded to original post and also to those that responded to today's frustrated post. When truck is fixed and hopefully it will be, I will post what the problem was and the solution. Thanks again. Trimman1224
Old Nov 16, 2014 | 05:11 PM
timbersteel's Avatar
timbersteel
You can also listen to the injectors and see if they are pulsing.
That's how I have diagnosed some that were dead.
Old Nov 16, 2014 | 06:30 PM
Island Time's Avatar
Island Time
What is the technique for doing this?
Old Nov 16, 2014 | 07:40 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Good point.
Try a mechanic's stethoscope.
Old Nov 16, 2014 | 09:52 PM
Island Time
Interesting, I wouldn't have thought about that as I think of using one for mechanical noises. But I guess an injector firing really is a mechanical noise as well. Thanks.
Old Nov 16, 2014 | 11:36 PM
timbersteel
A mechanics stethoscope is the tool of choice. I have used a 3 ft. piece of 3/8ths clear polyethylene tubing. Its flexible and can be used for reaching under the plenum.
Meant to add that earlier, just didn't have time to elaborate.
sgauvry
13
Jun 16, 2015 04:27 AM
cgouldy
1997 - 2003 F150
Apr 9, 2013 05:19 PM
flt04lee
Oct 16, 2008 06:32 PM
billsdaddy
Dec 31, 2005 08:41 AM
arnolan
Bronco II
Dec 1, 2004 10:34 AM
