What's up Hank , check the temps at 65mph flat road should be with in 15deg mine with the new oil cooler is 3/6 deg diff as far as the rest of the sensors test in park koeo , low , high 2500 some normal ford spec's=
ICP- koeo-0 low-625.5 high-1400-1450 psi
ICPV-koeo-0.2 you need .85 to start , lo-1.0, hi-1.8vlts
Thanks Scott and Rusty. Just got my truck all dialed in and was hoping to stay on top of my Exc.
I`ll go check those #`s now Scott. btw when are you back over in my area?
If your lookin at the values from the sheet ( https://www.ford-trucks.com/forums/a...1&d=1364848489 ) the ICP is 0.2 KOEO but that's really voltage or ICV. I don't think Ford has given us any guidance for ICP in PSI. Mine reads 0 also.
Yea 0 is no PSI hank but you still need 540 psi to start the truck , I'm not sure, they gave the floor job to someone else they were in a Hurry, No big Shakes. I'm Heading to Arizona (again) to take care of my Dad at the end of the week are in need ? Shoot me over a PM
