Oil Cooler Test
The (Ford) test I used was almost impossible to do or get repeatable results, so I likely replaced a good oil cooler with a new one.
The one most go by is the flat ground, engine fully up to temp (coolant around 190 or above), mildish OAT, cruising at 60 - 65 mph with an empty truck. 15 degrees max oil temp above coolant, but many folks are leaning towards the oil cooler is getting questionable between 10 and 15 degrees higher. This is a much more easy to do right test - my truck runs in the 6 to 8 degree oil above coolant temp. range.
Someone here may know what the temp differential is to set the wrench light on...
Diesel Dan is right, Check item 5 b. That's where the issue is. Unrepeatable. Scott's suggested substitution has been pretty well accepted as the standard way to check it.
I think this is the details of the last calibration version with the coolant/oil temp monitoring. Sorry for the repeating language but I got it like that:
TSB 09-24-3 6.0L DIESEL CALIBRATION UPDATE - VARIOUS ISSUES
Publication Date: November 20, 2009
FORD: 2003-2005 Excursion
2003-2007 F-Super Duty
2004-2010 E-Series
This article supersedes TSB 9-7-11 to update the model years covered and Integrated Diagnostic System (IDS) calibration level.
ISSUE:
Some 2003-2007 F-Super Duty vehicles, 2003-2005 Excursions and 2004-2010 E-Series vehicles, equipped with a 6.0L diesel engine may exhibit hard start, no start, white smoke, lack of power, running rough condition after cold engine start up, or diagnostic trouble codes (DTCs) P0404, P0470, P0611, P1260 and/or P1378 issues. Refer to the Calibration Content for information detailing specific vehicle content by vehicle application and model year that is being addressed by this calibration update.
This article includes previously released calibration content that improves injector performance in cold engine operation and additional diagnostic capabilities and product protection strategy enhancements. These enhancements provide additional diagnostic capabilities, adds additional new DTCs and engine protection strategies. Refer to the Calibration Content for additional details. See the appropriate Powertrain Control/Emissions Diagnostic (PC/ED) manual for technical descriptions and diagnostic routines associated with new DTCs.
ACTION:
Reprogram the powertrain control module (PCM) using IDS release 63.13 and higher or 64.01 and higher. The transmission control module (TCM) and fuel injector control module (FICM) , will automatically update if they are not at the latest calibration level. This new calibration is not included in the VCM 2009.11 DVD. Calibration files may also be obtained at MOTORCRAFT PARTS FOR FORD, LINCOLN OR MERCURY VEHICLES.
CALIBRATION CONTENT
Reprogram the PCM to the latest calibration following Workshop Manual (WSM), Section 418-01.
The PCM and FICM calibration update contains improvement actions to address the following symptoms:
2005 F-Super Duty 6.0L:
False DTC P0470 - Exhaust pressure sensor A circuit fault due to a freezing condition.
False DTC P0404 - Exhaust gas recirculation (EGR) performance due to a stuck turbocharger condition.
Cooling loss protection - Revised engine protection strategy when an engine over-temperature condition is present. Vehicles updated with this service calibration will display higher temperature gauge readings when high engine oil temperature (EOT) conditions or high engine coolant temperature (ECT) are encountered and may disable EGR operation to prevent possible EGR cooler damage.
Oil cooler efficiency monitor - DTC P012F stored and wrench warning lamp illuminated when the oil coolers efficiency drops below a specified threshold for a given speed and vehicle load condition.
Turbocharger vane sweep strategy - Performs a sweep of the turbocharger vanes and unison ring during stationary idle conditions. Vane sweep can occur once per hour to help reduce turbocharger sticking.
FICM low voltage detection monitor - DTC P0560 stored and wrench warning lamp illuminated when PCM vehicle power (VPWR) parameter identifier (PIDS) is below 10.25V for 60 seconds or below 9V for 4 seconds.
Turbocharger over boost detection - DTC P0234 stored and wrench warning lamp illuminated when a turbocharger over boost condition occurs.
2006-2007 F-Super Duty 6.0L:
False DTC P0404 - EGR performance due to a stuck turbocharger condition.
Cooling loss protection - Revised engine protection strategy when an engine over-temperature condition is present. Vehicles updated with this service calibration will display higher temperature gauge readings when high EOT conditions or high ECT are encountered and may disable EGR operation to prevent possible EGR cooler damage.
FICM low voltage detection monitor - DTC P0560 stored and wrench warning lamp illuminated when PCM VPWR PIDS is below 10.25V for 60 seconds or below 9V for 4 seconds.
2005-2007 And 2009-2010 E-Series 6.0L:
False DTC P0470 Exhaust pressure sensor A circuit fault due to a freezing condition.
False DTC P0404 EGR Performance due to a stuck turbocharger condition.
2008 E-Series 6.0L:
False P1260 induced during cranking due to low battery voltage.
Generic on-board diagnostics (OBD) improvements including; Mode 1, Mode 2, Mode 4 and J1699 OBD data test results as reported to the service tool.
Previous released calibration content included in IDS software release 48.2 or higher for: 2003-2007 F-Super Duty, 2003-2005 Excursion and 2004-2008 E-Series 6.0L diesel equipped vehicles:
White smoke, lack of power, running rough condition after cold engine start up due to injector spool valve sticking internally during cold engine operation.
No start/hard start when accompanied with DTC P0611 (FICM Performance), P1378 (FICM System Voltage Low) and/or all eight (8) injector circuit codes.
The new calibration changes the frequency of injector spool valve shuttling under certain conditions and will sound differently from previously released versions.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
092403A 2004-2010 Econoline, 2003-2007 F-Super Duty, 2003-2005 Excursion 6.0L: Check For DTCs And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 0.6 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
RECALEM 04
Here's where all this nonsense started. Another guy who didn't like the factory test, threw together a database, then the damn fool let it all get wiped when Webshots changed their photo site. It was a good collection of data but it showed you would change the numbers with speed, load (weight or grades), and to a smaller extent, ambient temp. In service cooler temps would change depending on how well cleaned the cooling system was done. Some continually increased, some slow, some fast; some clogged immediately (Nylyon when chem flushed after cooler install), and some went 25k without change like a new truck.
EOT vs. ECT after oil cooler replacement - Page 3 - Diesel Forum - TheDieselStop.com
So there's a lot of variables, but you must check out the sensor zero point of the sensors first. And what is an unknown is sometimes on a rebuild you may have a small amount of debris come loose and partially restrict the cooler. Then maybe under the ideal 60mph, no load condition you could have a 10°F differential, and it stays that way due to no more silicate or debris restrictions. With that info it's easy to declare this the norm. But the only way to despute that is to do an autopsy on the cooler, and that ain't worth the trouble for the situation.
lol
