My fuel had isn't working right. When I fill it up it doesn't go all the way to full. It goes just a little over 3/4. When it shows empty I still have half a tank or so. I put a new sending unit in the tank after the gauge stopped working and now I got this. I'm getting closer to a functioning fuel hand.lol What do I need to do?Any ideas?
either the new sending unit is incorrect (wrong resistance range) or the float could have a small pinhole allowing gas to enter..making it heavier and therfor won't "float" as high in the gas...
They don't come with a float afaik. Replacement sending units are often adjustable for calibration of the gauge indication by means of a set screw on the float arm. Don't bend the arm.
Genuine Ford fuel tank sending units come with the float and gasket, so do Carpenter's repro's.
Dunno if any other the other repro parts sellers/auto parts store replacement sending units come w/the float...or not.
No, some people bend the arm (on purpose) to try and calibrate the gauge indications. Instead, use the set screw provided to adjust float height. In particular, bending the arm won't work if the gauge reads low with a full tank.
