General Diesel Discussion
Please be lenient
Old Nov 5, 2014 | 06:21 PM
Joe_fummins's Avatar
Joe_fummins
Please be lenient
So I have an 89 f350 with a 12 valve cummins swapped in, like that when I got it. Brakes are soft despite bleeding and new master, so my question is, if there's not a vacuum pump being driven off the belt, where/how am I getting vaccuum? Also are there any things I can do to get a stiffer pedal or am I on the right track? Thanks guys
Old Nov 5, 2014 | 06:27 PM
bashby's Avatar
bashby
Lack of.vaccum will cause a really hard pedal that takes a LOT of pedal effort to stop, not a soft pedal.
Old Nov 5, 2014 | 07:29 PM
tecgod13's Avatar
tecgod13
Did you bleed the RABS valve? its on the frame under the front of the cab on the drivers side.
Also did you bench bleed the master first?
Try gravity bleeding all the sides in the right order, working from farthest away to closest to the master. Gravity bleeding meaning just open the bleeder and let the fluid flow out by itself. These trucks usually do pretty well that way.
Oh! are the rear drums adjusted correctly?
Follow the vacuum lines back from the booster and you'll eventually find a vac pump of some sort. It could be an electric one.
Old Nov 5, 2014 | 07:36 PM
Joe_fummins
Thanks!
You guys rock, gonna try that, it's got the cummins setup so the ps pump and vacuum pump are stacked running off the same gear, gonna try the reseal kit from goulds if I can't get anything out of the stuff you guys recommended
Old Nov 6, 2014 | 06:29 AM
Prototypemech's Avatar
Prototypemech
Can you post pictures of your engine compartment?
Old Nov 6, 2014 | 01:50 PM
tecgod13's Avatar
tecgod13
What reseal kit are you talking about?? There is a better chance of there being an issue with your new master than a problem with the vac system.
Old Nov 6, 2014 | 11:05 PM
Joe_fummins
Abs valve?
Talked with vacuum pump guy he said to adjust drums and bleed abs valve before getting that kit, my question is can I just Gravity bleed it or do I need to have help? Was gonna try today but it's 40 and raining and I lack a garage so I'd like to knock this out tomorrow but wasn't sure about the abs valve
Old Nov 7, 2014 | 06:06 AM
tjc transport's Avatar
tjc transport
i ain't rite
i always gravity bleed without any problems on any vehicle i have bone it on.
Old Nov 7, 2014 | 08:28 PM
Joe_fummins
At a loss
So some genius decided to bypass the abs valve, so I thought maybe I have no proportioning valve now? If the abs valve doesn't control that why does? I wasn't able to find anything for a proportioning valve anywhere so I could really use some help
Old Nov 8, 2014 | 05:09 AM
tjc transport
i ain't rite
the RABS has been bypassed on my 88 since the truck was 4 months old.
when it worked, it worked halfassed.. when it did not work(most of the time) hte truck had no brakes. bypassing the RABS on my 88-91 trucks was the best modification i ever did to them.
Old Nov 8, 2014 | 09:19 AM
Joe_fummins
The plot thickens!
Thanks for the heads up on the abs, turns out there's a tsb for the booster, they're known to have a leak issue, got the updated part number, just gotta track one down and wait for pay day
LSO1123
20
Nov 28, 2012 08:22 AM
hardwaterfreak
Dec 22, 2011 07:56 PM
firemanp
Sep 22, 2010 07:15 PM
highboy
May 30, 2007 07:15 AM
Diesel Tech 27
Jul 28, 2006 05:17 PM
