E4OD Problem, I think.
Old Nov 5, 2014 | 05:55 PM
terrylamar's Avatar
terrylamar
I think my E4OD transmission is acting up. It shifts "normally" as far as I am concerned through third gear. When shifting into overdrive, it started out by stuttering a bit. This has, progressively, gotten worse. Now, not only does it stutter, but between 50 mph and 59 mph, it feels like something is out of balance. It improves, slightly, at 60 mph. When slowing down, at times you can feel the entire truck pitching and yawing.
If it isn't the transmission, something is out of balance and I can't find it. I don't think it is the engine, I can rev. it while in neutral and everything seems fine.
I'm thinking now may be the time to switch over to a manual transmission rather than rebuilding this one.
But, what do I know, I'm not a mechanic!
Old Nov 5, 2014 | 07:32 PM
madMatador78's Avatar
madMatador78
How about u joints? Carrier bearing? My first thought was torque converter, but don't quote me on that. Hopefully someone else will chime in soon.
Old Nov 5, 2014 | 07:55 PM
terrylamar's Avatar
terrylamar
The U joints and Carrier Bearing seem fine. I have examined them visually and tried to move them.
Old Nov 5, 2014 | 08:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you didn't remove the driveshaft to check the carrier bearing and ujoints you have no idea if they are good or about to fail. It is impossible to check them with the driveshaft installed in the truck.
Old Nov 5, 2014 | 08:40 PM
terrylamar's Avatar
terrylamar
OK, but, do the symptoms I've described warrant me taking off the drive shaft to check it out?
Old Nov 6, 2014 | 08:03 AM
Mark Kovalsky
Yes it does. If it isn't in the driveshaft I suspect an engine miss. But the driveshaft fits your symptoms better.
71cc
May 15, 2012 11:49 AM
gearjockey550
May 31, 2009 09:09 AM
gladesteen
Nov 4, 2008 12:13 AM
dodmort
Sep 30, 2008 09:48 PM
kaufhaus
Jun 21, 2004 11:10 PM
