Scott's 61 F100 build.
This is what I started with in Jan. 2014.
For the most part a solid 1961 f100 step-side. It was originally I6 with a manual trans. When I bought it the previous owner had already done the Crown Vic. swap and had a Explorer 8.8 in the rear. He had planned on using a 460 and a C6 for engine and trans. For $1000 I didn't think it was a bad deal. The 460 and C6 also came with the truck with various other pieces.
I was able to sell the 460 and some of the parts that came with it for $650 dollars and my search was on for a different power source. As luck would have it I found a 4.6l engine, transmission and rear end out of a wrecked 2000 Crown Vic. with only 24,000 miles on it for $1500 off of Craigslist. One of the first steps was too mock up the motor and trans.
I also new that I wanted to get rid of the leaf springs in the rear and I also felt it would be better too use the rear end that was matched to the rest of the drive train so I pulled the Explore rear and used the rear from the Crown Vic. The Explorer rear had 3.73 gears and the Crown Vic . has 3.55. I also picked up a triangulated 4 bar off ebay and a set of coil over springs and shocks for the rear suspension.
I moved the rear end back about 3/4 of an inch so I could use the original aluminum driveshaft.
Here are some more pic's of the engine install. The brake booster is from a 2004 crown vic with a mid 90's explorer master cylinder and a generic GM disc/disc proportioning vale.
Here is a picture of the fuel tank install.
The rear cross member need to be moved a little for the tank to fit. I also need to grind some on the frame and add some rubber strips between the frame and fuel tank to keep it from rubbing metal to metal. I also needed to cut some off of one of the cross braces on the under side of the bed so it would clear the top of the fuel tank.
