Oil Filter Cap
Old Nov 2, 2014 | 09:16 AM
bthr22's Avatar
bthr22
Oil Filter Cap
The previous owner apparently didn't have a large enough socket to remove the cap, so used either channel locks or a pipe wrench to unscrew it. The top is stripped pretty much round as a result, so whenever I change my oil I'm stuck using a pipe wrench, which tears it up even more. It doesn't help that it's relatively soft plastic.
So my question is, are there any companies that make OEM spec. aluminum caps? I know the deal with only sticking with OEM due to sizing differences and letting unfiltered oil pass, but a metal cap would hold up better over time. If there aren't any available, where is the best place to find an OEM plastic cap?
Old Nov 2, 2014 | 09:26 AM
woodlander's Avatar
woodlander
I think SinisterDiesel has a billet aluminum cap on ebay, but expensive. I buy my ford parts from fordparts.com. autonation ford white bear lake.
Old Nov 2, 2014 | 10:02 AM
bthr22's Avatar
bthr22
Thanks, Woodlander. Ill check those out!
Old Nov 2, 2014 | 10:22 AM
woodlander's Avatar
woodlander
I should clarify. When on fordparts.com choose autonation white bear lake as dealer.
Old Nov 2, 2014 | 10:27 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Do a search Ford 6.0L billet oil caps. There are a few. Spendy though.
https://www.google.com/search?client...UTF-8&oe=UTF-8
Old Nov 2, 2014 | 12:13 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Quicktricks sells one too...
6.0L Billet Oil Filter Cap
Josh
Old Nov 2, 2014 | 12:17 PM
69cj's Avatar
69cj
I'd stick with the OEM and use the proper tools. Problems have arisen with some non oem caps.
Old Nov 2, 2014 | 01:08 PM
bthr22's Avatar
bthr22
Thats what I'm worried about, which is why I asked here before. I have the right socket, but the current cap is too stripped around the nut. It still seals fine though, so I'm not worried about it until the next change.
Old Nov 2, 2014 | 02:19 PM
Texas Bob's Avatar
Texas Bob
I have done 24 oil changes with the OEM oil cap and probably around 10 fuel filter changes with the OEM fuel filter cap. Both caps are in great shape. The secret? Only use 6 point sockets and put a thin rag between the cap and the socket so there is no wiggle room. Lisle makes sockets for the 6.0 and they can be acquired in many places on the internet and probably locally as well. After you do your next oil change, calculate your savings over a razzle dazzle aftermarket cap, put it in a savings account for when you will need it for parts down the road. It helps if you establish a relationship with you local Ford house. I generally look up what I need in genuine Ford or Motorcraft parts online, print it out and take it to the local Ford house and ask if they can meet the price. If they don't , I just say I wanted to give you the "last look", smile and head out the door. Sometimes they meet a comparative price, sometimes they don't.
kurboman
Feb 10, 2014 10:10 PM
A/Ox4
Jun 7, 2011 10:16 PM
Ted928
2004 - 2008 F150
Mar 16, 2009 06:21 AM
carsrob1
6.4L Power Stroke Diesel
Jan 11, 2009 08:46 PM
Hjudge49
Jun 30, 2004 10:49 AM
