Steering Box Seal Kit?
Old Nov 1, 2014 | 10:54 PM
kboldin's Avatar
kboldin
Looking for any recommendations on excellent quality seal kit for a 73 F250 Steering Box? Autozone lists one but not sure if that's the best quality kit out there. The number on the gear box C7AR-3A587A, also is this power assist or power steering, kind got lost in the threads. BTW, takes about two weeks but it drains the pump pretty well dry while parked.
Old Nov 2, 2014 | 10:18 AM
1972RedNeck's Avatar
1972RedNeck
Is the seal at the bottom of the box leaking? If yes, I think you need a new (or remaned by Readhead) gearbox as they don't have a bushing or bearing and the case wears causing too much slack for the seal to seal.
Old Nov 2, 2014 | 11:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford/Saginaw P/S gear box has a built in flaw, there are no bearings on the sector shaft, it rides directly on the housing.
Before too long, fluid begins leaking from the sector shaft seal.
Auto parts store 'rebuilt' steering gear boxes are nothing more than resealed gearboxes.
Red Head takes the gear box housing, machines it, installs the bearings that Ford omitted, so they could sell a gazillion seal kits.
Both the input shaft seal kit & the sector shaft seal kit are available from Ford and auto parts stores.
These two kits fit myriad 1965/2002 Passenger Cars, 1969/91 trucks and etc.
Old Nov 2, 2014 | 11:54 AM
kboldin's Avatar
kboldin
I really hate planned obsolescence, like all things you pay for what you get. Redhead is pricey compared to a reseal kit, I'll have to think on this one.
Old Nov 2, 2014 | 12:02 PM
4x4slik's Avatar
4x4slik
I put a seal kit in mine with the future plan of a redhead box. My suggestion is to remove and replace the input and output seals. The bottom one is not bad to replace on the truck, but, depending on orientation of gear, the input seal is not so much. Removing it gives you the ease to access both area's and clean it up better. you will need to bleed the system, but if you follow steps posted many times in the forums, it is not a bad process. Good lick.
Old Nov 2, 2014 | 12:48 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Have you been here and looked over the info on the seal kit #'s and remove and replace instructions?
https://www.ford-trucks.com/forums/1...then-some.html
Old Nov 2, 2014 | 01:58 PM
kboldin's Avatar
kboldin
I take that back, I just got under the truck and it looks like the output shaft is leaking as well. Truck is still new to me and working through all the kinks. I think I'll pull it and get it on the bench for inspection. I'll know more then.
kboldin
Dec 7, 2014 10:20 PM
mhancock2
Sep 26, 2011 10:40 PM
triskit16
Jan 3, 2009 04:43 PM
Bookman
Nov 30, 2007 08:49 AM
Six Niner
Jul 16, 2007 11:22 AM
