Pwer Assit vs Power steering
Old Mar 12, 2010 | 01:43 PM
dsm8's Avatar
dsm8
Question Pwer Assit vs Power steering
I have done some searches but come up empty on this.
Is there a difference between having power steering and power assist. I have a 78 4x4 with power steering. Pump on the motor, with a power steering box on the frame rail. What I cant figure out is how this differs from power assist. Can someone post a picture showing the difference.
Here you can see the pitman arm attached to the power steering box on my truck.
F150 Modificatins - DSM8's Photos
Sorry cant attach a pic
Old Mar 12, 2010 | 04:15 PM
HIO Silver's Avatar
HIO Silver
PS vs Power Assist
According to forum users, your set up is considered power assist (or Integral Power Steering). Power steering would have a hydraulic ram.
I swapped in the system from a 78 Bronco on my 73 F-100. Love it.
Old Mar 12, 2010 | 09:44 PM
Deluxetruck's Avatar
Deluxetruck
That is incorrect. Power assist would be a system with a hydraulic ram "assisting" a manual steering box. Integral power steering "integrates" the power assist in the gearbox. There is no hydraulic ram in an integrated power steering system.
-Jared
Old Mar 15, 2010 | 09:39 AM
HIO Silver's Avatar
HIO Silver
-Jared
I respectfully disagree on your nuances.. and I didn't say there was a hydraulic ram in the integrated PS system.
Integral power steering has the pump feeding the steering box. Power steering has the pump feeding the hydraulic ram.
Old Mar 15, 2010 | 10:46 AM
zak8tac's Avatar
zak8tac
Um no sir... Power assist utilizes a control valve and a power assist cylinder on the front member...Assisting the manual gearbox.
DSM8 your picture proves that you do not have the power assist set up as there would be a power assist ram from your axle tube to the drag link
Old Mar 15, 2010 | 02:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by dsm8
I have a 1978 4x4 with power steering.
1978 4WD's did not come with Power Assist P/S. Power Assist is not Integral P/S, the two P/S systems are totally different.
Power Assist P/S applications:
1973/77 F100 4WD / 1975/77 F150 4WD / 1973/77 F250 4WD (1977: High Boys only).
1969/74 Econoline's.
1953/80: Myriad Passenger Cars.
With Power Assist, there is a separate control valve and ram cylinder. The steering gearbox is of the manual type, because...it has nothing to do with Power Assist P/S.
Integral P/S: 1966 thru today F100/250 2WD's / 1969 thru today F350's / 1977 F250 4WD's (not High Boys) / 1978 thru today 4WD's / 1972/96 Bronco's / 1975 thru today Econolines.
With Integral P/S, everything is contained within the P/S's gearbox.
1973/77 F100/150 4WD's / 1973 F250 4WD's / 1974 F250 4WD's before serial number T80,001 used Garrison Power Assist P/S.
1974 F250 4WD's from serial number T80,001, 1975/77 F250 4WD's (High Boys) used Bendix Power Assist P/S.
Garrison P/S parts do not interchange with Bendix P/S parts. Thes two 4WD P/S systems are totally different, sharing only the P/S pump.
1978: Ford changed the P/S pump on everything (includings cars) except Econolines. This pump has a plastic reservoir and dipstick.
1965/77 P/S pumps have a steel reservoir and dipstick. The P/S pressure hoses are specific to each type of pump, so are most of the mounting brackets.
Old Mar 16, 2010 | 03:45 PM
dsm8's Avatar
dsm8
Is there an advantage of one over the other when dealing with a lift and larger tires (35") I am considering full hydraulic steering but dont believe that would be the best choice for freeway travel so I am looking to see if there is a better choice and dont know if the power assist is the better choice of the two for this specific application.
Old Mar 16, 2010 | 03:54 PM
NumberDummy
You do not want Power Assist P/S...almost all the parts are obsolete, mucho expensive when you do find them.
Mounting Power Assist on a non High Boy would be a royal PITA, a modifiers nightmare. Forget it.
Old Mar 16, 2010 | 03:58 PM
dsm8's Avatar
dsm8
You do not want Power Assist...almost all the parts are obsolete. Only a few seal kits can still be found new at dealers, obsolete parts vendors.
Mounting Power Assist on a non High Boy will be a royal PITA. I doubt it would even doable.
Not only is the frame different, but so is the steering column, linkage and etc.
Well then I guess that makes it easy either run with the stock or work on a ram assist after market application. Thanks for the info, that is what I was trying to determine.
Old Mar 16, 2010 | 04:26 PM
75F350's Avatar
75F350
A stock 78/9 4x4 steering box is a good place to start, but you do not want to use the stock push / pull steering design for a lifted truk.
Crossover and hydraulic assist is the way to go.
Old Nov 15, 2011 | 12:41 AM
BobbyShane's Avatar
BobbyShane
To NumberDummy: I have a 1975 F250 4x4. Right now I see that I have the Bendix type power/assist/steering? I just bought the truck and it does not have a power steering pump, it was gone/is gone. Of course it is a bear to steer. If I was to get a pump for it, would it simply be power assist or power steering. I have heard a lot about using a steering box from a 78'-79' steering box. Do you have an opinion on what would be the best way to go to make mine true power steering??? Thanks to You or anyone that can help with this. Shane
Old Nov 15, 2011 | 12:37 PM
montana_highboy's Avatar
montana_highboy
Assuming the other components are in place, i.e. control valve, power cylinder and supply/return lines you'll have power assist steering, otherwise, it will be just as it is now, basically manual steering.
Old Jan 2, 2012 | 02:48 PM
BobbyShane's Avatar
BobbyShane
I'm a little ignorant with this so please bear with me.
What do you mean, 75F350, when you say to go with a crossover or hydrolic assist is better? Thanks, Shane
Old Jan 2, 2012 | 11:46 PM
BobbyShane's Avatar
BobbyShane
78'-79' Steering boxes.
Ok fellas, this question goes out to all of you guys: I keep hearing that getting your hands on a 78-79 F250 4x4 steering box, to make my 75 4x4 highboy with power assist power steering integral power steering, is hard to find. O'Rielly Auto Parts tells me that they have them, fully refurbished, with a lifetime guarantee for $212 with an $89 core charge. Can anybody confirm this? Is it that easy, or are they selling the wrong item. Thanks, Shane
Old Oct 29, 2014 | 08:29 PM
breakstuff's Avatar
breakstuff
Hi, I have a 77 high boy and I just had the power assist valve rebuilt .. hooked it up and it spins the wheel to the left on its own and stays there tight enough where it stops the pump... need some help please
