Sponsored by: Real Truck
what do i do
Old Nov 1, 2014 | 02:14 PM
rws60's Avatar
rws60
what do i do
i have a 2004 6.0 i put 2 heads on it a year ago with the good studs did egr delete oil cooler, so last week truck would not crank so i sent it to my buddys shop he found some metal in motor,he got it running went picked up truck which is about 15 miles got home cut it off and wouldnt start again so i pulled that 12 mm alan head bolt out the one at crank shaft pulley and a roller bearing fell out and from what i have seen on you tube it is out of a lifter so you know what that means tear it apart would you build that motor,get a short block from for ford or has anybody ever heard of black water engines in virgina
Craig Maffet
Jul 20, 2017 01:32 PM
Tideman
Mar 29, 2016 01:13 PM
rws60
Nov 2, 2014 06:04 AM
crock0_6
Jun 11, 2012 06:53 AM
darrens697
Jan 28, 2010 10:33 PM
