6.0 engine problems
Old Jun 10, 2012 | 02:35 PM
crock0_6's Avatar
crock0_6
6.0 engine problems
My 04 F350 6.0 has been sitting for about ten days. I started it up and was about two miles from home and it was putting out white smoke. I drove it about five or six miles and when I pulled in the drive it had popped the degas bottle top off. Engine temp was ok. With the engine running I added some water. I then shut the engine off to look for the cap and when I started the engine again it sounded like it was running on about three cylinders and water was coming out of the exhaust. About 40,000 miles ago the egr cooler and oil cooler were replaced and arp studs installed with heavy duty head gaskets. Does this sound like the egr cooler and oil cooler let water into the exhaust or a blown head gasket. Anything I can check to be sure...Help appreciated.....
Old Jun 10, 2012 | 03:11 PM
RPM371's Avatar
RPM371
What were the "heavy duty" head gaskets? From what I've heard OEM is the best available. Black Onyx have a poor track record.
Old Jun 10, 2012 | 03:21 PM
crock0_6's Avatar
crock0_6
Not sure. Ford did it. I supplied the ARP studs. They supplied the gaskets. They said it was bullet proof with the new studs and gaskdt
Old Jun 11, 2012 | 12:00 AM
loganmuxlow's Avatar
loganmuxlow
Sorry ford doesn't properly check the heads. They need to be check for cracks, pressure tested, magna fluxed, hardened seats and checked for flatness.
If your heads aren't flat they have a good chance of letting go again.
Old Jun 11, 2012 | 01:12 AM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Power Stroke Diesel forum.
Old Jun 11, 2012 | 06:53 AM
bismic's Avatar
bismic
https://www.ford-trucks.com/forums/1...nts-degas.html
Traisc
May 25, 2015 09:02 PM
Angrywasp
Apr 2, 2012 04:11 PM
Hocky54
Oct 18, 2011 09:35 AM
Justinbel4
Sep 17, 2010 04:43 PM
Gt-358
Sep 15, 2005 05:09 PM
