Just drain or flush?
Old Oct 31, 2014 | 10:20 AM
KDAVID1's Avatar
KDAVID1
Been reading up and was thinking since my Temps are still good to just to a drain and fill back up with Ford gold? Would it be better maintenance to do a flush and full or would a drain and fill be just as good?
2006 F350 4X4
Old Oct 31, 2014 | 11:11 AM
Money-Pit's Avatar
Money-Pit
If the coolant looks clean coming out....drain/refill.
If it has some debris in coolant, flush with water only, no chemicals.
Old Oct 31, 2014 | 11:22 AM
KDAVID1's Avatar
KDAVID1
Got it. TKS
2006 F350 4X4
Old Oct 31, 2014 | 01:04 PM
KIDkiser's Avatar
KIDkiser
You will still have to get all the ford gold out,to get a 50/50 mix
Old Oct 31, 2014 | 02:04 PM
Mcrafty1's Avatar
Mcrafty1
If it's 50/50 now whatever stays in will be fine as long as you mix the new 50/50 before you pour it in.
Old Oct 31, 2014 | 03:49 PM
oldmanAZ's Avatar
oldmanAZ
2006 F350 4X4
If you have Ford Gold coolant and are staying with that, it simplifies things greatly. Just drain and refill.
When changing coolant types, or you don't know what is in it now, you need to do a thorough flush of cooling system; mixing coolant types can cause serious problems. There are many posts in this site about flushing etc.
Consider adding a coolant filter, too. Check this site. Either the filter helps or those that install them do a better job of routine cooling system maintenance. Tough to tell which is true, but considering how expensive these trucks are, a coolant filter seems like cheap insurance.
2006 F-350 Lariat Superduty LWB SRW
White over Arizona Tan*Line-X Bedliner*4" MBRP Turbo Back*Blue Spring*SGII *XDP Coolant Filter*FICMRepair.com w/Eco Tune* Edelbrock Shock Absorbers*Archoil*Rotella T5 10W-30
*Elite Diesel Torque Tow 155cc Injectors
Old Oct 31, 2014 | 04:47 PM
jswartz84's Avatar
jswartz84
I wouldn't just drain and refill. Wash all the old crap out. You don't need to use chemicals, just use distilled water. Essentially, you will be doing a flush, but it will be with plain water.
Old Oct 31, 2014 | 05:42 PM
69cj's Avatar
69cj
I agree 100% with Jswartz.
Old Oct 31, 2014 | 06:49 PM
Rusty Axlerod's Avatar
Rusty Axlerod
While I respect the environment and understand capturing the chemicals (both antifreeze and cleaning chemicals) for recycling, just pouring water in there and letting the engine run and then draining out ain't doing much flushing. To get the crap out of your cooling system and fully remove any cleaning chemicals you're gonna have to use a hose and MANY gallons of water and pull the block drains, run water through every opening. If you want to see some flow, rev it with the block drains out and a hose in the degas bottle. Now you're flushing.
I agree tap water is bad for your cooling system so a couple of dainty flushes with distilled are called for before going back with the coolant.
Also, if you just drop the coolant and refill, you'll be using premixed I guess? Or guess at what half full is and leave enough room for the concentrate? Drop and refill seems like a terrible idea to me no matter what your temp spread is.
Old Oct 31, 2014 | 07:01 PM
Money-Pit's Avatar
Money-Pit
I assumed he knows the history of the coolant.
If you bought the truck with whatever is in it, and you don't know when it was put in....yes flush it.
Old Oct 31, 2014 | 07:13 PM
jswartz84's Avatar
jswartz84
The problem with just draining and refilling is half of the systems coolant is still left in it. If you flush the system with distilled water a couple times you can start over with new coolant.
Old Oct 31, 2014 | 07:50 PM
KDAVID1's Avatar
KDAVID1
Thanks all. I think that's the key with mine. Although it looks fresh I couldn't say when it was put in. I'll stick with a water flush and refill. Sound's like the best idea. When I first bought the truck I had planned on putting in a coolant filter in but not thinking that so much now. Proper flushing seems to do the job.
2006 F350 4X4
landscapeguy
6.2L V8
Mar 30, 2017 10:19 AM
obiwan kenobi
Jul 19, 2015 11:42 AM
02GrayPowerStroke
Feb 28, 2010 09:33 AM
renoduckman
16
Mar 3, 2009 06:22 PM
rmilchman
23
Feb 6, 2008 07:59 AM
