drain coolant
Old Mar 3, 2009 | 01:28 PM
renoduckman's Avatar
renoduckman
drain coolant
Ok men i need help. I know this has come up before but i cant find post. How do i get all the coolant to drain out of my 02 Powerstroke? I dont have the desire or the guts to play with any block drains. I have the truck sitting with the front down hill to help out. Seems like im only getting about 5 gallons to come out. I did buy the corrrect gold coolant to replace so i wont have any odd mix problems. Thanks Joe
Old Mar 3, 2009 | 01:31 PM
Izzy351's Avatar
Izzy351
Joe,
You'll need to pull the block plugs back by the oil filter mount & starter, and you still will be about a gallon or two short of it being completely empty. Best thing to do is to keep cycling distilled water through it until it runs clear. Then drain, and fill with four gallons of concentrated (NOT 50/50!) coolant. Top-off with distilled and you'll be right at 50/50.
Old Mar 3, 2009 | 01:32 PM
87 F-150 I6's Avatar
87 F-150 I6
So your draining it from the radiator drain plug on the drivers side right?
- edit - Slow typing, DHO
Old Mar 3, 2009 | 01:36 PM
renoduckman
drain
Yes im draining it from the radiator drain plug. Still waiting to see how much comes out. I did buy my distilled water also. Thanks
Old Mar 3, 2009 | 01:37 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
The block plugs aren't that big a deal, really. I drained my block 8 times when I switched over to Rotella ELC (Red Kool Aid). Even if you're putting the same stuff back in, it would still be good to do it at least once.
The ONLY way you'll have a shot at getting all the coolant out is by pulling the drain plugs. Well.... I guess you could blow pressurized air through too... but they are called "drain" plugs for a reason...
Old Mar 3, 2009 | 01:42 PM
87 F-150 I6
Right, I ran distilled water thought it twice to clean out the system, you probably wont get it all out the first time. I don't know how good compressed are is to the system, I would be afraid to do that much. I would run it with distilled water until its clear, then fill it up with the new coolant.
Old Mar 3, 2009 | 01:46 PM
renoduckman
distilled water
So you refilled with distilled water and then ran that way to warm up. Then redrained again? Sounds like a good idea
Old Mar 3, 2009 | 01:50 PM
87 F-150 I6
yup did that twice, it was clear after the second time. The only down side was it cost a lot for that much distilled water, but I it was definitely worth the price.
Old Mar 3, 2009 | 01:55 PM
renoduckman
ok
Ok sounds like a good idea. The distilled water is cheap at walmart close by. And as said above, then fill with mostly antifreeze becasue therw will be about 3 gallons of distilled water still inside? Makes sense. I dont want to get too far off on my mixture of antifreeze.
Old Mar 3, 2009 | 04:34 PM
F250_'s Avatar
F250_
Perhaps a tad off-topic, but related all the same.
I just got a thought regarding these wonderful block drain plugs.
Has anyone tried connecting a common run of hard tubing to the plugs with a tee that then goes to a plugged isolation valve? This would make draining much easier and cleaner for sure. I'm thinking that a few compression fittings and small diameter tubing would be just the trick for this. A sketch of this concept is below.
Old Mar 3, 2009 | 04:52 PM
Bowie's Avatar
Bowie
I have a 2003 f350 with 50,000 miles. How long before I should change the fluid. It still has the stock fluid I assume. Not trying to jack your thread.
Old Mar 3, 2009 | 04:58 PM
big poppa's Avatar
big poppa
Not a bad ider Pete. Subscribing...
You got the 100,000 gold like i had, your good til then.. Then do the ELC with the proper flush and your good for awhile.
Old Mar 3, 2009 | 05:05 PM
Ponyboychris's Avatar
Ponyboychris
Are those drain plugs a hex fitting? I never had the pleasure of changing the antifreeze yet but just wunderin'.
Old Mar 3, 2009 | 05:07 PM
renoduckman
I appreciate everyones help here. There is allways some one on the site who can bail me out of a problem over the years.
I took the advice and flushed mine out twice with the distilled water. Then filled back up with 4 gallons of the zerex antifreeze. Toped off with more distilled. Good advice given above.
Regarding the time of when to change. Yes the book says 100k for the yellow antifreeze but i think it also says there is a 5 year change on that. I was going by 100k myself untill i realized that my truyck is 6 and 1/2 years old allready. Might want to recheck but i think it says 5 year 100k for the gold. Thanks Joe
Old Mar 3, 2009 | 05:42 PM
F250_'s Avatar
F250_
Chris... it's a recessed square drive... the 1/4" tip on your small 1/4" ratchet works perfectly. You can also use a short extender for the driver side near the oil filter, but you can't use any extender at all above the starter... just not enough room. (If you don't have a 1/4" ratchet, you might be able to get away with using the 3/8" to 1/4" converter with your 3/8" ratchet.)
