Fuel Pressure Spikes Cold Engine
Old Oct 25, 2014 | 08:01 PM
ebbnflow's Avatar
ebbnflow
For the first 5 minutes of my drive every morning, I see this:
I rebuilt the FPR a few months ago because the pressure was high all the time. Could injector O-rings cause this? Thanks in advance.
Old Oct 26, 2014 | 08:15 PM
ebbnflow's Avatar
ebbnflow
Maybe it's my glow shift sensor, but I've got a feeling something else is going on. Anyone??
Old Oct 26, 2014 | 09:08 PM
TKegs763's Avatar
TKegs763
I can't see the video, but my fuel pressure first thing in the morning is 6-8 psi higher than it is after it warms up. I'm curious
Old Oct 26, 2014 | 10:54 PM
ebbnflow's Avatar
ebbnflow
I edited the link. I think it works now. Thanks.
Old Oct 27, 2014 | 06:08 AM
Tugly's Avatar
Tugly
I can't read the numbers, but I offer a counter-thought. Could your FP be low, and it restores momentarily? That looked like air bubbles in fuel, or a poor electrical connection.
Old Oct 27, 2014 | 06:12 AM
Pikachu's Avatar
Pikachu
You might try putting a mechanical gauge on it as a test to eliminate the electric gauge itself as the problem.
Old Oct 27, 2014 | 07:47 PM
ebbnflow's Avatar
ebbnflow
Thanks for the suggestions. I did the hutch and harpoon several years ago. I've got 2 clamps on the lines at the tank. Quick connects are long gone. I think a little clear tubing is in order.
I wish I had a mechanical gauge to try. That would rule out a faulty pressure sensor.
Old Nov 17, 2014 | 04:42 PM
ebbnflow's Avatar
ebbnflow
I just wanted to post an update. After 10 months if service, the sensor on my glow shift fuel pressure gauge is the culprit. Confirmed by a mechanical fuel gauge and my multimeter. Glow shift was kind enough to send a free replacement.
I wonder if it failed because:
1. I run 100% biodiesel.
2. I neglected to remote mount it. I mounted it directly to the back of my fuel bowl post filter.
3. It is cheap Chinese c.r.a.p.
So let me ask this:
For anyone running a glow shift 0-100psi fuel pressure gauge. How long did your sensor last? Where did you mount it?
Thanks.
terrymargate
6.7L Power Stroke Diesel
May 8, 2018 11:32 PM
20powerstroke02
Jan 10, 2014 09:41 PM
Farmboypowerstroke
May 26, 2010 10:45 AM
oldblue31
13
Nov 30, 2006 05:20 PM
