Oil Leak
Old Oct 24, 2014 | 01:24 PM
bobwhyte2002's Avatar
bobwhyte2002
Oil Leak
Hello
I just did an oring kit for my fuel filter . I changed all fuel lines etc. No diesel leaks . I cleaned right down to metal. So I can see everything . I have done a lot of work on truck but still need help. It looks like it is leaking on the drivers side. Between the IHOP reservoir and the block. It is right near a plug. It seems to be seeping there. Not sure about it . Does not look like it is coming from the pump. Is there a gasket there? Thx
Old Oct 24, 2014 | 05:00 PM
427 fordman's Avatar
427 fordman
Can you post a picture? I'm not exactly sure where you are talking about. The hpop can leak at the hose connections, or the unserviceable plug on the bottom. There are orings on every plug in the valley on the heads.
I'm just not exactly sure where you are talking about so a picture or a little more of an explanation would help.
Old Oct 24, 2014 | 06:04 PM
madpogue's Avatar
madpogue
You just made me hungry.... (so should the IHOP reservoir be checked, and kept full of maple syrup? )
Old Oct 24, 2014 | 10:01 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Nyuk nyuk nyuk. There is a plug behind the front cover to the right of the hpop. It's the check valve for the hpop depending on year. I don't know if the 94-5's have it but the 96-7 do. There is a o-ring on that plug
Old Oct 24, 2014 | 10:10 PM
oldbird1965's Avatar
oldbird1965
In every group there has to be a smart a**! Would you pass the pancakes please.
Old Oct 24, 2014 | 10:41 PM
MOOSE_MACHINE
Seems like most of them land here
Old Oct 25, 2014 | 11:53 AM
BBslider001's Avatar
BBslider001
True story for sure
Old Oct 25, 2014 | 09:42 PM
ReBilld's Avatar
ReBilld
I had a leak exactly where you are describing and mine turned out to be the front cover leaking. There is an oil port from the front cover to the block there. The o-ring seal for the front cover was leaking. I had to pull the engine to fix it . I hope this isn't where yours is leaking.....but I'm also afraid it is.
Old Oct 25, 2014 | 09:46 PM
ReBilld's Avatar
ReBilld
Here are some pics of where mine was leaking.
jpcjguy
Sep 20, 2012 11:21 AM
RNH Performance
Aug 6, 2011 09:04 PM
outdoormaniac
24
May 14, 2010 03:03 AM
88f1504x4
Mar 30, 2006 04:44 PM
Joe98684
Feb 26, 2006 12:15 PM
