Rough Idle
Old Oct 23, 2014 | 09:29 PM
elim's Avatar
elim
Rough Idle
I'm getting a little miss at idle on my 7.3 and at times when driving will give me 2 shots of sputter and return to normal.My mechanic has checked all he could,he is at a loss,checked wiring,took valve covers off,checked injectors,scanner gives him nothing.Only thing I had done on it was a cam sensor couple of weeks back when it didn't want to start.Not looking for it to die on road and winter is around corner.All ideas are welcome---thanks
Old Oct 24, 2014 | 11:05 AM
Tugly's Avatar
Tugly
Where did you get the CPS?
Old Oct 24, 2014 | 11:10 AM
montanasteve's Avatar
montanasteve
First, check your oil level, make sure you're not low. Our trucks use the oil to fire the injectors. If you're on the verge of too low, could be causing your problem. Have you changed the fuel filter lately?
shark1979
Nov 23, 2009 10:28 PM
snowmanroy
Jun 17, 2009 05:23 PM
'86_150
Mar 22, 2009 06:04 PM
PAVEMENTMAN
Apr 29, 2008 08:21 PM
lifted_01_SD
Apr 25, 2006 02:42 PM
