Rough Idle when warm
Old May 9, 2009 | 06:05 PM
snowmanroy's Avatar
snowmanroy
Hey guys I have a 95 superduty I just recently swapped a boneyard engine into the engine drives out great plenty of power no smoke whatsoever but the problem I'm having is when the engine gets up to temp it starts to idle real rough shakes the truck abit even its kinda like a camed engine would idle only does this when warmed up when the engine is cold it idles flawlessly I've already changed out the cps and icp planning to swap out the ipr next in an atempt to remedy the idle one thing I did notice that may or maynot be related is when i installed the engine and changed the fuel filter there was oil mixed with the fuel in the fuel bowl so I'm thinking this truck may also need injector o-rings anyone have any ideas I may have missed???
Old May 19, 2009 | 09:42 AM
clint95powerstroke's Avatar
clint95powerstroke
my trucks doin the same think, im leaning toward the ipr. i think its stickem and thats whats causein it to have that rough idle. let me know if it fixes it man.
Old May 19, 2009 | 09:51 AM
MustangMatt96GT's Avatar
MustangMatt96GT
Injector o rings will cause this from what I've been told. Mine does the same thing.
I put some Lucas oilstablizer in and it helped a little too.
Old May 19, 2009 | 10:56 AM
Action4478's Avatar
Action4478
IPR o rings ,my bet ,,a cheap test ,, injector o rings next if not .....Stay away from oil additives ,,a good brand of oil is sufficient ...
Old May 19, 2009 | 11:39 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Agree with Rick. and read this for the oil additives:
What about Additives?
Old May 19, 2009 | 05:24 PM
snowmanroy's Avatar
snowmanroy
well I've swapped in a new ipr with new o-rings still acting up when warm I'm going to change out the injectors and o-rings next I figure atleast I don't have to worry about a cps icp or ipr sensor problems for a while
Old Jun 17, 2009 | 12:39 PM
Lambo333's Avatar
Lambo333
I also have quite a bit of lope at Idle, even after warm up... even more so perhaps. So, I'm going to start with the IPR valve seal kit, I've found this one online:
7.3L Powerstroke IPR Valve Reseal Kit
Is this what I want? Is it the same kit for all 7.3L PS engines? I have a 95.
Old Jun 17, 2009 | 02:13 PM
Action4478's Avatar
Action4478
That is what you need ,,Did you try international ?...
IPR O-Ring Kit (for when IPR valve replacement is not required)
(Ford) F6TZ-9C977-AA
(International) 1825806C92
Old Jun 17, 2009 | 02:40 PM
Lambo333's Avatar
Lambo333
What are the symptoms if replacement is required?
Old Jun 17, 2009 | 02:47 PM
Lambo333's Avatar
Lambo333
Thanks for the part number.
I just called the dealer in Belgrade, and they sell the kit for $17.99. He's shipping it to me in Helena for another $5. So, it saved me a few bucks and I supported my local dealer
Old Jun 17, 2009 | 04:39 PM
Action4478's Avatar
Action4478
When Mine was ready to crap out , the truck smoked like a freight train at start up ...eventually ,, the IPR stuck (open ) left a no start....
Old Jun 17, 2009 | 04:58 PM
Lambo333's Avatar
Lambo333
Hmmm... what color smoke? I've noticed I end up with a decent amount of white smoke at start up. I just kinda figured it was normal. The truck does have 189K miles, and I'd wager that the IPR has never been replaced.
What does an IPR cost?
Old Jun 17, 2009 | 05:23 PM
Action4478's Avatar
Action4478
mine smoked so bad I was afraid someone would call the fire dept ...
IPR from ford is spendy (300.00),,,Ebay usually has them 150.00 or so ..wouldn't hurt to have a spare ...BTW , my truck has 177 on the clock ...(title said 199)
northwindone
Modular V10 (6.8l)
Apr 11, 2013 12:10 PM
Damo67
1978 - 1996 Big Bronco
41
Jan 6, 2013 10:38 PM
palaka
Dec 15, 2009 07:00 PM
Robvan
401, 477, & 534 SD Engines
Jun 10, 2008 10:25 AM
Keelbar
Oct 10, 2001 11:07 PM
